warning about DBA rotors!
Hey Guys,
I got a set of DBA rotors from Tirerack. I though that they would be good for tracking because they have a nice venting systems on the them. They are also slotted but in a way were you get a lot of contact to pad.
Well after three track days hair line cracks started to show up on the outer slot. and one of my rotors cracked. I was running carbotech xp8s on them.
Anyway nice rotor for the street but if you are going to make some track runs stay away from them.
I just picked up some Stoptech slotted rotors. Ill let you guys know how they hold up.
K~
Pics will be up later when I figure out how to do that.
K~
our stock rotor are vented(front at least), slotted doesn't add contact to the pad, it actually has less.
the cracking is very common for aftermarket drilled/slotted disc, what happen most of the time is they are not casted with the hole(unlike brembo's bbk) and the slot, instead they are just machined out of a solid blank which damage the structure integrity of the disk. i cant say for sure about your brand since i do not have the experience nor the engineering spec of it.
again, you dont need anything more than blank disk for the street.
turbo8765
Nov 21, 2012 07:54 AM
