Sponsored by: CARiD
What is the best fitting rollbar, no interior, no soft top
Old Aug 28, 2020 | 06:55 AM
CarBoN's Avatar
Default What is the best fitting rollbar, no interior, no soft top
bolt in roll bar, no interior plastics, no soft top, which bolt in
roll bar will fit the tightest to the chassis and to the hard top
Old Aug 28, 2020 | 07:42 AM
spaded.racer's Avatar
Something custom.
They're all made to fit under the soft top, so if you want it to fit tighter to a hardtop it would probably be best to go custom.
Old Aug 28, 2020 | 08:10 AM
engifineer's Avatar
Yep, the Hard Dog, for example is meant to fit up against the soft top. I dont think they have another version than that. And most others will be the same as far as I know. And since I am sure the various hard tops are a bit different, best to choose your top and have the fabricator build to that one to get it as tight as you can.
Old Aug 28, 2020 | 02:43 PM
Chris_Lum's Avatar
When going custom, you also may want to think about whether you want your top to be removable and if so, which catchers you are using--OEM w/handles or bolt on brackets. I believe harddog style bars and similar require the OEM handles to be bent due to the proximity to the main hoop. If you get a custom bar that sits even closer to the hardtop, then you might not be able to use OEM catchers at all.
Old Aug 29, 2020 | 05:50 AM
CarBoN's Avatar
How much do you guys think a custom might run?
the hardtop doesn't need to be like quickly removable , so aftermarket brackets that just secure the hardtop would be fine
Old Sep 1, 2020 | 12:07 PM
Slowcrash_101's Avatar
Depends if you're bolting it in vs welding, and where you plan to attach it. That's labor, and of course material costs. Whether you want it painted, or the type of metal can have a huge influence in cost. A mild steel cage vs chromoly vs inconel/titanium/carbon if you want to start getting exotic.
Jobsee44
Cars for Sale
May 26, 2019 09:17 AM
shasha
Cars for Sale
Jul 7, 2017 06:41 AM
JC2K
Feb 11, 2016 07:33 AM
