Sponsored by: CARiD
what Engine Mods prior to FI?
Old Apr 7, 2010 | 06:03 AM
lobzdik's Avatar
Thumbs up what Engine Mods prior to FI?
My ultimate engine build has always included a small turbo like GT2860RS, with a well built and responsive bottom end. But I have always been fond of an approach that is backwards to what most people go for: building the bottom end etc first and only then FI.
Engine Build Example (outline not including ECU & Support mods)
Stage 1: I/H/E, maybe intake manifold/throttle body + tune (breathing)
Stage 2: injectors, fuel rail/lines/pump/filter etc +tune (fuel)
Stage 3: light flywheel, cams, valve springs, piston heads/rods, maybe crank etc + tune (internals)
Stage 4: FI
So my question is: can you do these mods FIRST, with enough provision for the extra power, strain etc that FI will bring, meanwhile running them efficiently on an NA engine (ignore the $ of this build for now)
***I thought of doing it this way, because I like the idea of keeping the engine as responsive as possible and keeping things smooth etc, rather than just dropping in a turbo for some cheap power***
Old Apr 7, 2010 | 06:47 AM
Gernby's Avatar
Former Sponsor
Stage 2 really just needs to be combined with stage 4, since you can do all of stage 1 and most of stage 3 with the stock fuel system. Basically, the stock fuel system is totally adequate until you go FI or increase displacement.
Old Apr 7, 2010 | 06:58 AM
chef-j's Avatar
I'd would do just intake, exhaust and clutch/flywheels. Also if you have extra $ think about brakes/some rubbers too.
And rest of all, I will think about when you go FI. Oh not bad to buy a ems and learn before go fi (if you plan to use one)
Old Apr 7, 2010 | 07:01 AM
chef-j's Avatar
^I meant by intake manifold*
Old Apr 7, 2010 | 07:02 AM
Gernby's Avatar
Former Sponsor
FWIW, my stock injectors are just at 83% duty cycle at 8400 RPMs with 13.1:1 AFR. This is with a pretty high barometric pressure too. I would be surprised if adding cams to my setup pushed me over 90%.
Old Apr 7, 2010 | 02:08 PM
AngryScotsman's Avatar
Assuming this is for a street car...
why brakes?
I ask cause, a car with 500hp stops the same as a car with 200hp
tires definitely make sense though
Old Apr 7, 2010 | 03:20 PM
camuman's Avatar
listen, none of this stage stuff is needed.
you want FI?
prepare to do a clutch
then do stand alone + fuel + FI after.
stock brakes work fine. stock everything else is fine. though tires may be screachin depending on how much power you wanna make.
Old Apr 7, 2010 | 03:29 PM
chef-j's Avatar
why brakes?
Base on my experience...when my car ran faster than before, i had to stop better than before. When 200whp car hit 60mph...500whp car will hit close to 100mph.
Btw i'm not talking about upgrade BBK, just get a better pads than stock for sure.
Old Apr 7, 2010 | 03:39 PM
lobzdik's Avatar
yeah the brakes/suspension/body work/weight reduction is on the list as well!
but I think of them separately from the engine build... this post was just about the engine build
Old Apr 7, 2010 | 03:56 PM
chef-j's Avatar
Yeah, you are right . I just realized it.
Sorry op, i fail.
