Sponsored by: CARiD
what lugs to use with d2's black rotas
Old May 5, 2008 | 06:46 AM
  #21
Nofar's Avatar
Adding to CoralDoc's reply, yes, you have to make sure the lug nut mating surfacing matches the wheel appropriately. I have the Rota D2's on my car and the stock lug nuts will not work properly with this wheel. The stock nuts have a "spherical" mating surface; you need an "acorn/tapered" shaped mating surface to seat to the Rota D2's. You can easily get these lug nuts at Discount Tire, or even Murray's. Additionally, you'll may need a thin walled socket extension to install the nuts without scratching the rims; just a word of caution because I had to deal with this.
As far as color, I'd stay stick with silver/chrome lug nuts on a black wheel.
Regards,
Christopher
Old May 5, 2008 | 12:28 PM
  #22
yellows2k_1226's Avatar
Regards,
Christopher
im actually using my stock lugs on the d2's ..it works for me ...i just had to use a long thin wall socket to clear the rims .....but im getting muteki
Old May 5, 2008 | 12:55 PM
  #23
CoralDoc's Avatar
Do not continue to drive the car until lug nuts with the correct seats are installed.
I have seen what can happen if you use a spherical seat lug nut on a tapered seat rim ... and it is not pretty. Even when properly torqued the lug nuts can loosen, and in one case I observed a wheel become liberated from the car at speed.
Old May 5, 2008 | 02:56 PM
  #24
spook's Avatar
Originally Posted by Emil St-Hilaire,Apr 11 2008, 05:19 PM
Ditch the Rotas.
douchebag.
i say black lugs.
Old May 5, 2008 | 04:22 PM
  #25
iwantyourcar's Avatar
watch out for muteki's that are colored, mine were blue and flaked REALLY easy
Old May 5, 2008 | 05:25 PM
  #26
P-CarDriver's Avatar
Originally Posted by yellows2k_1226,Apr 27 2008, 11:12 AM
anybody with a muteki lugs w/ rotas ? how are they ?
Im using the muteki SF48's with my slipstreams, seem to scratch easy(i have the dark gold color) but it might have been because i took my wheels off and on about 50 times for rolling/cutting/checking over the first week of having them, but other than that there awesome and VERY cheap
Old May 5, 2008 | 07:22 PM
  #27
yeah i know..thats why im about to buy muteki this wednesday to change them ?? they're safe right ?
Old May 6, 2008 | 02:16 AM
  #28
CoralDoc's Avatar
If they have the same seat as the rims, then yes, they are safe. It's easy to check. When you have the rims off the car inspect the design of the lug nut seat on the rim. It will either have a flat seating surface or a curved one. The S2000 OEM rims have a curved seating surface (=ball or spherical seat), whereas most aftermarket rims have a flat seating surface (=tapered or conical seat). Honda is one of the few manufacturers that uses a ball seat and that is why Honda OEM lug nuts should not be used on most aftermarket rims.
Also, it is important to be careful when buying aftermarket lug nuts that you use the correct ones for your rims. E.g. do not use the common tapered seat lug nuts on OEM rims. I have seen this occur when owners want to use light weight or special design lug nuts on thier OEM wheels. Knowledgeable venders will correctly guide the purchase, but some purchse the wrong ones due to lack of knowledge about this important design consideration.
As I mentioned above, the consequence of using the wrong lug nuts can be dire. Mis-matched sets do not mate with the rim properly, can loosen and fall off = not a good thing.
This whole discussion about color is secondary to the critical need to use the correct design lug nut.
Old May 6, 2008 | 11:53 AM
  #29
ay for example ...... its not like ima buy these on ebay ..but its the same ones as these that this performace parts store was selling around me ...are these okay ?
http://cgi.ebay.com/ebaymotors/Muteki-CE-L...sspagenameZWDVW
Old May 6, 2008 | 01:09 PM
  #30
AJR LKF's Avatar
you can give our T1R lug and lock nuts a shot.
http://aj-racing.com/catalog/product.php?p...35&cat=0&page=1
http://aj-racing.com/catalog/product.php?p...13&cat=0&page=3
Sam @ AJ Racing
