Sponsored by: CARiD
Wheel Bearing Question
Old Jul 14, 2012 | 05:14 AM
GravyRobber's Avatar
Default Wheel Bearing Question
Hi all...
I'm planning on changing both of my rear hubs and wheel bearings over the next couple weeks.
I found rear hubs online for cheap, so I am just going to have the bearings pressed on and swap the entire unit.
My question is: are wheels bearings the same on for front and rear? All of the bearings I see listed online are "front fitment". I've yet to see one specifically for the rear, so I am assuming they are the same.
Thanks
Old Jul 14, 2012 | 12:59 PM
Btrthnezr3's Avatar
Hey I saw this
http://www.carpartswholesale.com/v5/...Wheel+bearing+
There is one listed for front and rear.
I'm in for an answer as I have a noise I think may be the bearing and hub. Trying to price out the cost on all this.
Old Jul 15, 2012 | 06:50 AM
I looked up some bearings made by National. They list the same p/n for the front and rear, so I think I am safe in assuming they are the same. I picked some up at a local auto parts store for $30 per bearing. I'm just going to replace both rears. I'm also going to replace both rear hubs with a Dorman OEM replacement p/n 930-465. If you shop around, you can find all the parts for ~$200. Not sure what labor will be. Hopefully not toooo much.
Old Jul 17, 2012 | 04:27 PM
avarela86's Avatar
Gravy can you post part numbers an where you got all your parts. I have to do the same and can't seem the find part numbers anywhere.
Old Jul 18, 2012 | 06:26 AM
Yup sure will. I'm on the road at the moment, but I'll do it when I get home Friday.
Sent from my iPhone using Tapatalk
Old Jul 18, 2012 | 08:14 AM
Driven's Avatar
Per www.hondaautomotiveparts.com
Front wheel
Rear Wheel
Number 36:
Front and Rear wheel bearing share same part number: 44300-S84-A02
$60.46 from there.
Additional info: Ball Bearing; Bore=1.7717", Outer Diameter=3.3071", Width=1.6535"
Timken and National part number: 510050
Berk/arnley part number: 0514140
SKF part number: FW145
Rockauto.com is a good place to cross-reference and get non-OEM parts from.
Old Jul 18, 2012 | 09:32 AM
TakeshiS2K's Avatar
For God's sake man go with OEM hubs. I bought one of those cheap hubs you're talking about and busted at least 10 wheel studs before I learned it was the hub and not the studs causing it. You know how much of a bitch it is to change the studs since you basically have to take the entire assembly apart to do so. Save time and a ton of heartache and just buy an OEM hub. Learn from my failure.
Old Jul 18, 2012 | 10:02 AM
I've already ordered the Dorman hubs. This is the first I've ever heard anybody complain about them.
Old Jul 18, 2012 | 01:15 PM
TakeshiS2K's Avatar
That is the exact brand I had, I was replacing studs on that thing almost every weekend. Went OEM and it never happened again.
Old Jul 18, 2012 | 02:13 PM
Driven's Avatar
how did you install the studs? hammered them in or did you use a stud installer tool?
Installation is usually the issue... aftermarket hubs aren't bad, just requires more care when installing studs and into the knuckle.
