Sponsored by: CARiD
wheel spacers
Old Apr 4, 2010 | 08:27 PM
hypforlife32's Avatar
Default wheel spacers
can i use these on the ap1, i see that they are universal. can i use the stock studs? i have the ap2v1s and would like them to stick out a little more front and rear. just seeing if these are good and are worth 40 bucks. thanks. also will i lose handling?
Old Apr 4, 2010 | 08:31 PM
sillyboybmxer's Avatar
u did not post anything for us to see.
but in general,....yes u can use spacers. 40 sounds too dang cheap for the right ones though
Old Apr 5, 2010 | 06:02 AM
lol wow i forgot to post link...
http://www.evasivemotorsports.com/merchant...S-PLATE-SPACERS
Old Apr 5, 2010 | 06:21 AM
kevos2k's Avatar
You can use them u will need extended studs
Old Apr 5, 2010 | 06:59 AM
Where can I find extended studs at?
Old Apr 5, 2010 | 07:02 AM
Dreaming_S2k's Avatar
You will not lose handling...in fact you may gain some due to the wider track.
Old Apr 5, 2010 | 07:15 AM
viets2000's Avatar
http://www.m2tuning.com/lugbolts_jdmstuds2.asp
http://www.racingworks.com/skunk2_ex...heel_studs.htm
lots of places. They're everywhere
Old Apr 5, 2010 | 04:35 PM
22calbr's Avatar
you need to press out the hubs and *should* replace the bearing to replace the studs. not cheap. get spacers with built in studs. easily found on ebay.
Old Apr 7, 2010 | 05:59 AM
RichV's Avatar
With spacers with built in studs, do you still have to press out the OEM stubs? How does that work?
Old Apr 7, 2010 | 08:12 PM
ans2k's Avatar
what is the minimum wheel spacer size that will fit the s2k oem rims without any mods? assuming they come with pressed studs. 15mm? 10mm? 20mm?
