Wheel Spacers For the S ?
^^^No, longer wheel studs are only required and come with the 15mm or less kits for H&R. The 20mm spacer is flush with stock length studs and the 25mm spacer is a tad longer than the stock length studs but you can still get the nuts on to tighten the spacers.
will these fit my s2k?
http://elpasoracing.com/lounge/index...=25572.new#new
or are they not right fitment?
Originally Posted by jdm_dc_fan,Oct 26 2009, 04:29 PM
I thought anything bigger than 5mm needs extended studs? I have 15mm spacer to clear my spoon calipers. h&r didnt want to seperate the spacers from the studs unless the spacers were 5mm or less.
Robear Racing H&R Spacers
These are 25mm H&R's for the rear.
Rubn1out4GudLuk - Where did you get the 20mm Fronts?
