Sponsored by: CARiD
Wider fenders
Old Oct 14, 2009 | 02:38 PM
clarkster009's Avatar
Default Wider fenders
I would like to get between 8.5 and 9.5" up front and between 9.5 and 10.5" in rear. Does anybody know what kind of mods are needed for this?
I thought I have heard people running as fat as 10" all around, is this true?? However, I wouldn't want to make too many compromises.
Old Oct 14, 2009 | 02:41 PM
nitewing117's Avatar
It will also depend on the offsets you're looking at. I'm running 17x9+45 all around, and that required rolling and/or increased negative camber.
Tire size will also be a factor in deciding how well they'll clear, but an overall rule is rolled fenders, cut bumper tab (rear), and negative camber.
Old Oct 14, 2009 | 03:02 PM
Thanks nitewing.
How much does rolling fenders generally cost? And is negative camber bad? Other than uneven tire wear I assume.
Old Oct 14, 2009 | 03:10 PM
I just borrowed a roller and did mine myself, so technically it was free. Just make sure to take your time and use a heat gun to warm the paint.
Tire wear - I don't have toooo much negative camber wear on the rears, but I have a ton more on the front for some reason. Increasing negative camber can increase your corner grip but decrease straightline. Just really depends on what you're doing and what your goals are.
Old Oct 15, 2009 | 08:19 PM
dtmcnamara's Avatar
im running 17x9.5 +38 on all 4. Fits great. Thinking about going with a 15mm spacer up front as well.
PS- I got J's fenders
Old Oct 18, 2009 | 05:04 AM
integlspwr's Avatar
the js front fenders allows you to run a 18x9.5 +42 with a 265 with no prob.
Old Oct 18, 2009 | 09:18 AM
edspecR's Avatar
fender rolls usually cost abount $80~$100 or so, ask around your community forums, im sure people'll do it for ya
Old Oct 19, 2009 | 10:32 AM
Were the J's direct bolt on? Do you have any good pictures of them on and painted?
Old Oct 19, 2009 | 10:43 AM
what size wheels fit on the Spoon fenders?
Old Oct 19, 2009 | 11:05 AM
kharaal13k's Avatar
j's wide fenders are direct replacement and will fit what you are wanting. cost about 500 each. wide body s2000's run i think a +15 offset though.
