Sponsored by: CARiD
Will a HFC get rid of drone?
Old Apr 12, 2012 | 07:07 PM
steve695's Avatar
Default Will a HFC get rid of drone?
Hey all.
I have a GReddy TI-C single cat back exhaust with my stock cat punched out. It sounds good at high rev's but anything before that it drones like hell.
Will a high flow cat get rid of the drone?
Thanks.
Old Apr 12, 2012 | 07:36 PM
s2000maniac's Avatar
not really i have skunk2 with hfc and it drones like no other. you are better off with a test pipe.
Old Apr 12, 2012 | 08:01 PM
TougeS2k's Avatar
Ya a test pipe will pass the resonance noise cleanly through, it will still be loud as shit but it will be behind you instead of under you.
Old Apr 13, 2012 | 12:44 AM
steve695's Avatar
I didn't think there would be much difference between a punched out stock cat and test pipe? They are essentially the same thing.
Having said that, I do have an Invidia test pipe sitting around some where that I bought and never put on.
Old Apr 13, 2012 | 05:07 AM
lopez14's Avatar
Put that test pipe on.
Old Apr 13, 2012 | 07:45 AM
unlewser's Avatar
It will get rid of some. I switched from a test pipe to a HFC and the sound didnt change much. A HFC sounds more like a test pipe than an OEM cat.
Old Apr 13, 2012 | 10:32 AM
whiteflash's Avatar
It probably won't get rid of the drone; just change its characteristics, generally for the better.
Old Apr 13, 2012 | 10:55 AM
TougeS2k's Avatar
I just got a 3'' berk header back /w HFC and it drones at certain RPM, i think its just the way it is
Old Apr 13, 2012 | 12:46 PM
DallasAp1's Avatar
it certainly wont eliminate all of it but it could help alot
i dont have your exhaust i run invidia dual n1 and after i added 70mm berk HFC it deffinitly reduced it some.
Old Apr 13, 2012 | 03:04 PM
steve695's Avatar
Thanks for the info.
I'm reluctant to run a test pipe as the fine for having one over here is very hefty.
