Sponsored by: CARiD
Yellow DRL? and HID at same time?
Old Aug 13, 2008 | 07:57 AM
khiz's Avatar
Default Yellow DRL? and HID at same time?
Hey,
i tried searching but couldnt find an answer.
Is it possible to get the day time running lights on with the HID's?
i want to put Yellow bulbs in it. also what bulb size?
has anyone done this? if so any pictures and DIY's?
Thanks
Old Aug 13, 2008 | 08:02 AM
HankookS2K's Avatar
are you talking about putting a yellow bulb inside your projector and running it as a drl? the projector is a D2S bulb size. you have to buy a 3000k temp d2s bulb for that.
if you just wanna run a yellow halogen bulb in your high beam area and run that as a drl that would be more appropriate so you can retain your regular hid.
Old Aug 13, 2008 | 08:50 AM
wOlLeyLaBeL's Avatar
i think hes talking about just changing the DRL light bulb to yellow...and having that DRL stay on while his projectors are on....
Old Aug 13, 2008 | 08:55 AM
HankookS2K's Avatar
well if his car is a 2003, he does not have drl's. the only way to get a drl into the ap1's is to purchase a relay made to power the high beam at half power. if thats all he wants to do a cheap yellow halogen bulb will work in the high beams. and you can wire that up so when you turn on your low beams your drls will still be lit.
Old Aug 13, 2008 | 09:11 AM
EP Heart's Avatar
If his location avatar is indicative of where he's posting from then he's from Canada. They had DRLs mandated many years before they started becoming common in the US.
Old Aug 13, 2008 | 11:59 AM
HankookS2K's Avatar
[QUOTE=EP Heart,Aug 13 2008, 10:11 AM] If his location avatar is indicative of where he's posting from then he's from Canada.
Old Aug 13, 2008 | 12:11 PM
Red Bull's Avatar
Im kinda in the same boat. I wanted to get yellow bulbs for my high beams but only want them to come on when i turn on my low beams. Is that possible? And how much work would it be to accoplish?
Old Aug 13, 2008 | 03:16 PM
HankookS2K's Avatar
youll need to purchase a drl relay. then youll just wire the 12v to the low beam so the relay will get power when the low beams are triggered. its not much work at all
Old Aug 13, 2008 | 04:05 PM
[QUOTE=HankookS2K,Aug 13 2008, 11:59 AM] ohhhhhh yea
Old Aug 13, 2008 | 05:58 PM
HankookS2K's Avatar
ahh, does the ap2 have a seperate bulb for the drl? or do they use the hig beam bulb?
