Your Handling Setup
I've been looking into doing a couple trackdays with my S, but I feel like the handling needs some work. All I have are KW V3 coilovers.
What are your opinions on strut tower bars, sway bars, etc? What setup do you guys have to increase handling? |
why don't you drive the car and work on driver mod and figure out what you need/want from the car before throwing a bunch of shit on it?
p.s. strut bars on this car don't do dick. |
You already have more than you need to start learning how to drive on track.
Save your money for track brake pads and fluid. You will need those long before you need any suspension changes. |
Brake pads, fluid, tires
Originally Posted by Back S2k
(Post 23483281)
p.s. strut bars on this car don't do dick. I have driven track couple times in a miata and I feel the S doesn't have as good handling stock as my miata with koni yellows with gc and sway bars. There is a lot of body roll compared to the miata. Thus, I'm seeking opinions. |
Pads, fluids, and tires are given.
I want to know if sway bars help the car hang through corners better. Significantly or minor? |
How does your alignment look like?
just go to the track and get seat time. no mods and u will go faster!
Originally Posted by Sexi2k
(Post 23483821)
p.s. strut bars on this car don't do dick. I have driven track couple times in a miata and I feel the S doesn't have as good handling stock as my miata with koni yellows with gc and sway bars. There is a lot of body roll compared to the miata. Thus, I'm seeking opinions. Body roll does not necessarily mean the car handles poorly. Likewise, lack of body roll does not mean a car handles well. Some people seem to mistakenly equate stiff suspension with minimal body roll as good handling - no. A 16kg coilover setup with poor dampening that cannot control the springs will turn slower lap times than a 10kg setup with the appropriate digressive valving curves. Again, driver mod - it works and is transferable from car to car. To echo the others, the only musts are: brake pads, fluids, alignment. |
The full adjust ability of the KW V3's is the only "handling mod" you need apart from seat time and some basic shock tuning knowledge. Get someone that knows what they're doing help you with the shocks and make sure you have a good set of tires, then just get out there and drive the car.
