There was a thread were someone put a rubber washer (like from your garden hose) on the shifter to fix the shift boot from falling down. I put it on and now my shift boot sits flush with my shift knob.
or get the short shifter and the boot will never fall down
External:
Blacked out tail lights - ***/$ pros: cheap, easy to do, goes with my red/black theme cons: illegal Volk LE28 - *****/$$$$ pros: light weight, great looking, JDM baller, rare, goes with my theme cons: expensive Interior: NRG steering wheel - ****/$$ pros: lighter than stock, smaller, feels much better, not too expensive cons: parking is sometimes a pain, illegal (removes airbag) Momo hub - */$ pros: easy to install, fits several brands of steering wheels cons: not a quick-release JPM accessories shift boot - ***/FREE pros: free boot and installation, won in WTD raffle, custom stitched, goes great with my red/black theme cons: none T1R shift knob - ****/$$$$ pros: shorter shifting, feels better, looks sweet cons: expensive for a shift knob, but worth it Performance: K&N short ram intake - ***/$$ pros: cheap, easy to install, good throttle response, no danger of hydrolock, good sound cons: on a hot day can cause engine bog, not as much HP as JDM intakes Slow Motion Motorsports custom 3" header-back exhaust - ****/$$$ pros: LOUD, nice and deep sound, 12whp gain, no other S2k sounds like mine cons: LOUD, needs tuned to be fully effective, have to find somebody willing to risk doing a cat-delete Toda spec B cams, cam gears, valve springs - ****/$$$$$ pros: world of difference, VTEC hits extremely hard, sounds amazing cons: EXPENSIVE, lopey idle, loss of power below 5,000RPM, runs pig rich without a good tune Advan A048 medium compound tires - *****/$$$$$$$$$$$$ pros: makes your car handle like a go-kart cons: don't even bother driving in the rain, plan on replacing rears every 5k miles, get your checkbook out ($1100 a set with mounting and balancing on stock AP1 rims, closer to $1400 for my Volks) Overall, I'm pretty happy with my mods so far. The red/black theme is coming together nicely. Performance wise, below 5,000RPM is very sluggish. However, when staying in VTEC, I usually have to short shift to keep from running into the person in front of me. From a 40mph roll in 2nd gear, I've pulled on a supercharged C5 and a Porsche 911. From a dig, very tricky to launch on street tires. Once you get up into the powerband where the cams really kick in, you tend to spin tires quite a bit. I would recommend milder cams unless you have a small nitrous kit or a supercharger to get more low end power. |
I'd be interested in seeing before/after dynos for those Toda SpecB cams. Do you have anything like that? BTW... you don't mention aftermarket pistons. I thought Toda said pistons (with deeper valve reliefs) were required for their SpecB & SpecC cams.
Bump for RLTC install.
TTT
Ckit - Im deleting your newest thread - since this was moved. |
Originally Posted by NVMY4N,Nov 23 2007, 07:06 AM
TTT
S2000 Owner for 4years and a few months. Car Purchased Bone Stock
MY: 2000 Silverstone Mods: Exterior: * Carbon Fiber Hood, Mirrors, Trunk - B/C I like it. * Gloss Black PCd AP1 Wheels w/ S-02 - B/C I like it. * OEM Lip - B/C I like it. * Megan Racing Coilovers - Big Difference - much :heart: - still needs adjusting though. * Windshield Tape Removed - B/C I like it. * Ricks Badges - B/C I like it. * Coastal Metals Front Grills - B/C I like it. * Key Hole Plugs - B/C I like it. Interior: Red/Black * Muz Black/Red Floor Mats - Way better than OEM - pricey but worth it. * AP2 Radio Door - B/C I like it. * AP2 Center Console - a must have * JPM Limited Editiion "S2000" Shift Boot - B/C I like it. * Skunk 2 Shift Knob - HATE IT - sets to high, investigating new options * 2003 Radio - Clock (thats it) * Rear Speaker Mod - extreme difference in sound compared to AP1 2 speakers. * Modifry Glove Box Organizer - Best MOD for the money by far. * MoMo Tuner Steering Wheel w/ NRG Carbon Fiber Quick Release Hub - Comfortable - lose Cruise Control - unless you hardwire it in. Performance: * Comptech Header * Comptech Exhaust * Comptech High Flow Cat *------ Comptech Titanium STB (not installed anymore SC clearance issues :( ) *------ Comptech Red Original STB (not installed anymore SC clearance issues :( ) (Yes, I still have both - they are just expensive towel racks) * Comptech Reinforced Diff - Must Have if you plan on making more HP or install gears. That little extra insurance goes a long way. * Ricks 4.57 Gears * Vortech SC'd w/ AC as of 8/22/2007 FTMFWii!!1! - excellent - Cons - I want more power. * Cusco Cooling Panel - Painted to Match Car - helps not much difference - Mainly cosmetic. * Stop Tech Brake Kit - Slotted Rotors, SS Lines, ATE Fluid, Axis Pads - OEM Brakes are fine - I think SS Brake lines (when installed and bled properly with a Good Brake Fluid makes a HUGE difference) Misc * Top Down While Moving Mod - If you don't have this mod, you'd better have a HT that never comes off. * Modifry Shift Beeper - Couldn't be happier with this mod - takes the guess work out of shifting, helps a great deal when you need to keep you eyes on the road and in ^ RPMs -( like when your on US129 ) * 2nd 12v Accessory Mod - Easy, inexpensive, and a big help if you need to keep wires out of the way while driving or if you need two things charging at once * Key Fob Active While in Ignition Mod - quick easy mod, that is helpful if you have a lot of passengers. * Cruise Control Hardwire (d/t loss of OEM Steering wheel) |
Engine: F20C
JDM Apexi VAFCII............................................ .....good mod for N/A:thumbup: PuddyMod Ram-Air intake with cold air venting........My own thing :heart: it Megan header with heat wrap................................good header for the money T1R 70RR exhaust single outlet...............................One of the best Spoon STB, rad cap, and thermostat NRG ETD with PuddyMod mount..............................looks cool, I like Mugin fan switch............................................ ........ good for Florida ARC titanium cooling plate.....................................looks cool, I like Buddy Club grounding kit & voltage stabilizer..........looks cool, I like Varies polished parts............................................A must have :D Transmission: KA6MT AP2 2005 6Spd...................YES, great upgrade One off prototype short throw gate shifter............My own thing :heart: it Spec light weight pressure plate OEM disc with S.S.line....Very nice :thumbup: AP1 14 pound flywheel.........................................I t is just that good Final drive Differential: Custom Reinforced diff with custom solid steel sleeve (no crush collar) Full cryo treated, Polished 4.56 gears, and a Kaaz 1.5 LSD.......built it my self so I know it is good :D Suspicion: RS*R TI2000 springs.................................... :heart: them Spoon X-brace............................................. helps at auto cross Spoon strut brace........................................looks nice and fits well AP2 V-1 wheels Bridgestone OEM Tires:........great for OEM Audio: JVC head unit with 3 |
CKit, can you post the link to where you purchased the RaceLogic unit?
