Backpressure: The MYTH and Why It's Wrong
Originally Posted by H22toF20,Mar 24 2010, 11:47 AM
^ 3" has made more power on EVERY Honda four cylinder dyno I've seen, near stock or not; if it was tuned obviously.
Designing around tuned length pipes so your standing waves provide scavenging is the most important part of header design.
I've seen crappy looking press bent headers of the right lengths outperform expensive work of art but wrong length headers.
Look for a dyno compairison of any Honda or N/A motor for that matter. You'll be surpriced that a 3" makes power EVERYWHERE in the powerband not just in the top end like everyone would think. This should tell you that exhaust velocity is complete BS; after the collector.
EDIT here's a link for the lazy
http://bbmoto.net/wiki/index.php?ExhaustTheory
Instead of linking to some website no one has ever heard of take a look at an exhaust built by some of the smartest people in the world (F1 engineers). You will notice that even on this 1000bhp motor they have an exhaust under 3"... Someone should tell them they could make more power
Funny thing about running a dyno is you can show a gain/loss for whatever you want...
Originally Posted by Angerman,Mar 24 2010, 05:48 PM
A 4 cylinder motor will have 4 distinct pulses per complete engine cycle, a 6 cylinder has 6 pules and so on. The more pulses that are produced, the more continuous the exhaust flow. Backpressure can be loosely defined as the resistance to positive flow - in this case, the resistance to positive flow of the exhaust stream.
Here's a picture of a measured exhaust pressure curve inside the header. Measuring was done 100mm after the exhaust valve and begin when the exhaust valves opens (Aö). The first peak (A2) is measured just before the piston reaches BDC (UT). There is a low pressure peak (A4) where the exhaust valves are wide open and a third low pressure peak when both valves (intake and exhaust) are open. This is an optimum for just this engine speed (3000 rpm in this case).
So if they have the ability to flow more, why isn't "wider is better" a good rule of thumb for exhaust upgrading? In a word - VELOCITY. I'm sure that all of you have at one time used a garden hose w/o a spray nozzle on it. If you let the water just run unrestricted out of the house it flows at a rather slow rate. However, if you take your finger and cover part of the opening, the water will flow out at a much much faster rate.
I didn't want this thread to turn into a debate but here you guys go.
You said that F1 Engineers run a smaller than 3" on their motors. I don't know what pictures you've been looking at but as far as I know all F1 motors run basically just headers. The exhaust system you are refurring to is part of the header itself; collector. The tuner from the link I gave you has even talked to an F1 Engineer and guess what? He said the same thing I'm saying.
You can throw theory's onto the table all you want. At the end of the day a theory is just a theory and nothing more. Their has been ZERO proof to argue that bigger isn't better.
You are right about being able to asque dyno numbers. But half of the dyno's I've seen have been from respected tuners. Not someone trying to sell a product.
