bkr8eix gap
OEM gap is 1.1mm as noted in the OEM plug part numbers but if you're still running a much higher compression ratio than stock your gap will need to be smaller for max performance.
What's the gap on these out of the box? Diddling with the gap requires keeping the ground and center electrode parallel. I've seen cautions to not alter the factory setting by more than 0.008" (0.02mm) which is darn near microscopic.
-- Chuck
-- Chuck
The plug is designed to run a 1.1 mm gap to have the ground electrode parallel to the center electrode, hence the 11 digits on it. If you buy the pre-gapped version it will come at 1.1 mm gap. Some of the NGK IX plugs can be bought without being pre-gapped, so you can gap them to 1.1 mm or whatever you prefer. Many people can't gap plugs with fine wire electrodes without causing damage, so NGK recommends not gapping them, but I've done it for years without any issues, you just need to do it right.
yellowf22c1
25
Jul 15, 2011 05:31 PM
