cel with berk test pipe
first off i would like to say that i did search and found nothing... unless i'm searching for the wrong thing....
i have a 2007 and a berk test pipe with the cel fix but i still get the cel... i heard that the 06 and up??? have this problem... any way to fix it... and again i did search so sorry if i piss you off with this thread...
I've had good luck with inlinefour's Blox. Here is the description and website.
"This BLOX Cel eliminator will gap out your o2 sensor from your catalytic converter, header, or test pipe. Having more exhaust flow through your o2 has a hard time to get a correct reading thus throwing a CEL code. Gapping it will help give it more space to have a proper reading. Let that test pipe or high flow cat be more effective by using this!"
http://www.inlinefour.com/blcelelad.html
you can try taking some iron wool and putting it in the cel fix and reinstalling it...... we have seen different results with different cars.... some cars you can try everything and you will still get a check light.
