S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Engine whine(without accessory belt)
Old 03-07-2019, 11:12 PM
F1TwoThousand's Avatar
Default Engine whine(without accessory belt)
F22C went with upgraded head build, installed new headgasket, reassembled and when the engine runs i hear this huge metallic whine sound. I figured/hoped it was a pulley so i ran the engine without a drivebelt and same sound. I installed a new oem timing chain tensioner, re installed cams and double checked my work(followef FSM to the T) unfortunately the sound still exists:
The way the whine comes to an end when engine is coming to a stop almost sounds like something sticking. Any ideas are highly appreciated.
Old 03-08-2019, 01:50 AM
flanders's Avatar
Did you torque the cam caps in steps and in the correct order?
Old 03-08-2019, 03:10 PM
s2000sccaracer's Avatar
Did you check for vacuum leaks? Try spinning the engine without spark plugs to see if you can hear the same noise? Remove valve cover to see if anything is rubbing.
Did you use assembly lube when installing the cams?
Old 03-08-2019, 06:13 PM
Did not use assembly lube when installing cams. Service manual didnt call for that buti did oil them up with engine oil. It did sound like a vacuum leak for a second buy if you listen closely the sound sounds from something spinning and only happens when engine is running
Old 03-08-2019, 06:16 PM
Ill take off and reinstall cams. The manual calls for 2 turns at a time when tightening. Also will make sure cams werent confused and switched
Old 03-08-2019, 11:14 PM
Found the problem.
I didnt line up the cam chain with its proper lining mark. I just skipped this important step and aligned the cams with the cam gear. Thats why the engine ran fine but all that slack was what was making the noise!
Old 03-09-2019, 02:11 AM
flanders's Avatar
How did you get slack in the chain?
It doesn't matter where those black chain links are as long as crank and cams are aligned.
Old 03-09-2019, 02:44 AM
I had an engine whine first start up after headgasket replacement. I took off the crank pulley and cranked the engine to see if that was the whine thats where i completely got it out of timing. Now when i insert the crank pulley and the cam gear is TDC it shows the pulley to be on BDC. Engine whine was i believe due to not putting chain on as marked, that created more slack on the non adjustable timing guide side vs the adjustable side guide where the timing chain tensioner is.
Old 03-09-2019, 02:47 AM
i got the chain on the cam gear properly now but the woodruff key wont go back into the engine. im trying to figure out if i need to hold the pulley and spin the cam gear to line them up
Old 03-09-2019, 03:22 AM
flanders's Avatar
Wow you cranked the engine without the crank pulley and woodruff key installed?
Both oil pump and the lower chain drive gear would then spin free on the crank snout, dangerous stuff.
Quick Reply: Engine whine(without accessory belt)
