S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
F1 and 2.0L S2K Engines
Old Jan 26, 2012 | 06:25 AM
wdtd's Avatar
Default F1 and 2.0L S2K Engines
Here is a quote from an article on Wikipedia:
"A 2.4 litre Formula One engine at 19,000 rpm has a 25 m/s mean piston speed (2 × 39.7 mm × 19,000 rpm/60 s), the same value as the Honda S2000 engine (2 × 84 mm × 8,900 rpm/60 s). This value is typically limited by increasing intake port velocities and frictional losses, but is attained by commercial vehicle engines, like the Honda S2000, BMW E46 M3's S54B32 with 24.5 m/s as far back as 2001, the Audi RS4 with 24.2 m/s or the Yamaha YZF-R6 motorcycle with 23 m/s."
Here is the link to the Wikipedia article:
Formula One Engines
Would also be nice to have 300bhp per liter, naturally aspirated! Or a power band at a little more than twice the RPM we regularly experience. Mercy!
Old Jan 26, 2012 | 06:37 AM
Reapur's Avatar
You have to remember that the FIA allows teams to go through a maximum of 8 engines per season, meaning every motor is built to last only a handful of races. Its nice to dream though isn't it ?
Old Jan 26, 2012 | 05:02 PM
FISH22's Avatar
Would this be the same case with the AP2? Obviously it revs lower. But I've read somewhere that an AP2 @ 8k, has the same piston speed as an AP1 @ 9k. True?
Old Jan 27, 2012 | 02:13 PM
ans2k's Avatar
nope. its about 8500-8600.
Old Jan 27, 2012 | 02:44 PM
FISH22's Avatar
Actually, did some more reading... and it seems an AP2 @ 8300 rpm has the same piston speed as an AP1 @ redline.
Old Jan 27, 2012 | 03:46 PM
Duke Togo's Avatar
The s2000 could rev higher but on of the first major issues would be valve float. You could increase the valve spring pressure but you would lose power by creating more friction.
F1 cars utilize many tricks but one of the most important ones has been pneumatic valves
Also they are using Ti valves and Aluminum- beryllium pistons and coatings and now liner less blocks with dry coatings. And MMC bearing less rods at least at one point
15 years ago the hot topic was spherical valves that would have allowed 20K rpm small displacement motors with huge gains in mileage but sadly coates pissed away the tech
Old Jan 27, 2012 | 04:47 PM
FISH22's Avatar
Wow, that's some insane engineering for just the valve operation.
Old Jan 28, 2012 | 05:15 PM
wdtd's Avatar
Some interesting reading about the S here, including bits of engine info ... So Long S2000 (Gone but Never Forgotten) ... enjoyed seeing the engine cut-away image too.
@ Duke Togo: Interesting you should comment about shperical valves and provide the image. I was pondering an idea that was different than pictured, but still rotating not reciprocating. "... coates pissed away the tech ..." meaning they patented portions of the product but then failed to fully develop it, so it's useless for anyone to take it further as long as the tech is protected by patent?
Old Jan 28, 2012 | 10:17 PM
Duke Togo's Avatar
It looks like all they ever have done with it is make harley engines and some farm equipment - the original design apparently ate through bearings until they went ceramic.
I don't know if it's too simple or the gas companies buried it or what happened but I think if an independent person produced something of there own design and approached the right company they could make it happen.
You can certainly make one for yourself to use, and you have to remember that even things like vtec weren't really Honda creation just there version of it.
Diablo99V
South Florida
May 16, 2007 09:00 AM
news2kroller
Dec 14, 2005 09:14 AM
zero_to60
Mar 24, 2004 05:29 AM
FormerH22a4
Sep 16, 2002 09:48 AM
S2K4ever
Jun 24, 2002 07:12 AM
