S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
J's Racing Header Install
Old Oct 10, 2012 | 05:44 PM
jon o's Avatar
Default J's Racing Header Install
ill be installing my j's header this weekend. Ive never done a header install on an s2000 yet. i will be using a lift for the install. does anyone have any tips for me? Is it easier to put this header in from the bottom or from the top.. Ive read so many mixed comments on this. Im guessing it will be easier from the bottom without taking the motor mount loose. Anyways any info anyone can give me or has done a js header install i would greatly appreciate it.
Thanks
Old Oct 10, 2012 | 06:08 PM
speedjunky01's Avatar
bottom is the way to go
with a lift it will be a LOT easier, put the header at a very steep angle with the exit of the header almost pointing at the ground then slide the head flange past the motor mount
If I can do it on jack stand, you can do it on a lift lol
Old Oct 11, 2012 | 10:30 AM
s2000maniac's Avatar
will be a piece a cake with a lift.
Old Oct 11, 2012 | 08:41 PM
jon o's Avatar
took the cat and facgtory header off tonight.. the hardest part was getting to the back bolt for the heat shield. took a bit to get the bolt loose to pull out the shield.. then trying to get the 2nd to last nut on the bottom side of the header.. Other then that everything came off easy.. header and test pipe should be here tomorrow.
Old Oct 12, 2012 | 10:21 AM
StrokerAce's Avatar
TTIWP!!! Haha
Old Oct 12, 2012 | 03:50 PM
jon o's Avatar
Fixing to put the header on. Will post a couple pics when I get it out of the box....
New Pics:
Old Oct 12, 2012 | 05:55 PM
MBHs2k's Avatar
Wow that thing looks beautiful
Old Oct 12, 2012 | 06:01 PM
jon o's Avatar
well im missing the donut gasket guess ill have to wait untill tomorrow to see if honda has one in stock.. if not i may use the factory gasket untill i can get the one it was supposed to come with.
Old Oct 13, 2012 | 05:28 PM
JayC07's Avatar
How much the header run you? That would sooo go hand jn hand with my j's exhaust!! How's the weight difference vs stock?
Old Oct 14, 2012 | 11:38 AM
S2000_sam's Avatar
UK Moderator
Thats a sweet looking piece of kit.......(and the rims)
Be sure to pump up some pics with it installed.
