Skunk2 intake manifold
#291
But Jason REALLY needs to improve on the quality of his s2000 fuel rail adapter brackets for this setup. I'm sure he'll make good on making the strongest brackets imaginable.. given my encouraging results, this is a nice opportunity for him
I'm currently broken down in CT (1h45m from my home in MA) because the fuel rail bracket broke on my way home from PA. Gas was spraying out of the top of the 4th cylinder's fuel injector (where it goes into the fuel rail) because the broken fuel rail bracket was no longer holding the fuel rail tight. Here are pics of my tale of woe. Of course I couldn't have today be perfect. WIn some and lose some. Thankfully I exited the highway within 30 secs and shut the car off at a rest area within 60 secs.. currently waiting for AAA ($500 tow home.. wheee)
#293
XPerformance may sell them on behalf of Jason at CNC Speedshop. Jason doesn't do direct retail sales anymore.
#294
as far as the 80mm or 90mm throttle body goes, k tuned makes both an 80mm and 90mm throttle body with the 86-93 mustang 5.0 bolt pattern.
#295
oh I know. I have the 74mm skunk2 throttle body on my car and I agree, it's trash. I've tried shaving down the blade a bit it has helped but it will still get stuck from time to time on deceleration.
#296
Damn that sucks...I guess you could always get a K fuel rail to avoid any bracket issues. But hopefully you're up and running soon!
Did you have to use two intake gaskets? One for the adapter plate to the block and one for the intake mani to the plate.
#297
SO I ran with your K-tuned suggestion and went with the KTD-TB8-IA--B 80mm TB. John at K-tuned has been great to work with. He helped come up with a solution for how I can use a slightly modified K-tuned throttle bracket so it'll be ready for install on delivery. Thanks b.r.i.a.n.!
#298
As for gaskets, yes I re-used a Hondata gasket closest to the AP1 head, then Jason @ CNC provides a gasket that sandwiches between the 2 halves of the F and K series adapter plates, and lastly a thin metal K-series (OEM afaik) IM gasket was used between the adapter plate and the skunk2 ultra race.
Be warned, if you go with the Hondata gasket (which is nice for the added thickness) the coolant passage is not there, would have to drill it out:
And you'd be wise to do so otherwise you'd be like me and have to resort to this hack (of parking up hill, with the radiator at highest point, with a leakless funnel) to get the air to bleed out of the coolant lines:
f20kills (04-21-2017)
#299
Cool..thanks for the info. I use Hondata too with my mani. No real benefit to it unless you're in stop and go traffic and only park/turn off your car for no more than 5 min.
I log my temps and it does nothing for the track. I wouldn't use it again lol
#300
Well, except it adds thickness to the runners. My outlook on it was: every little bit should help. The fact that I got some serious increase at 6200, and even much lower, makes me happy
