Stock injectors for bolt-on
to get the most out of cams you would want to change the time too and so to get the most hp and reliable build. i would recommend the aem 1052u standalone ecu.
Or "cheat" and get an adjustable fuel pressure regulator for $100 and continue to run stock injectors. There is always a vafc or emanage at that point to fine tune your fuel adjustments. E manage if you need timing control.
Concerning the standalone and parallel ecu our friend has a lot of choices (vafc, emanage, aem, hondata etcetc). The point here is that for sure with stock injectors he can play safely!!! If he is feeling unsafe then plug a fuel pressure regulator (as s2000Junky said) and you are more than ok!!
Thanks alot huys for the help
I already have AEM ECU and a FPR cuz the car was turboed
I guess ill keep the stock injectors and tune it with bolt ons
Im not going to buy the cams anytime soon, till then stock injectors it is
Originally Posted by JUSTINTHECOASTIE' timestamp='1348624466' post='22038245
You will be fine with stock injectors with drop-in cams and bolt ons
