S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Test Pipe ?
Old Nov 19, 2009 | 12:13 PM
CarbonS2kEddy's Avatar
skunk2 makes a 70mm test pipe its only got 1 02 bung though
Old Nov 20, 2009 | 05:23 AM
ap1_tot's Avatar
Originally Posted by s57_s2k,Nov 18 2009, 07:34 AM
I am confused , should I order 63mm or 60mm ? .
to put things into perspective for you
Stock cat and exhaust has an inside diameter of 60mm. if you wish to get a test pipe wit the same diameter as the stock exhaust, then get the 60mm. it will already give you gains since the stock cat has restrictions inside it as you can see. if you have upcoming plans on modding the car, get the 63.5mm or 70mm.
Though, IMHO, a 63.5mm test pipe would be the best application for an N/A car. That was my 1st mod and it was just a custom one. I honestly didn't feel any gain however i didn't feel any "bottlenecking" as well. BUTT DYNO wise. Atleast, when you get the 63.5mm it will still be applicable if you get a bigger aftermarket exhaust. I even heard on a build here somewhere that a 63.5mm test pipe connected to a single 70mm exhaust will give you better mid range gains than a straight through 70mm one. ill try to look for that thread. they have the dyno numbers and it was tuned via engine management so i guess its reliable.
but then again, each mod will react differently to each car. but i'm just stating my opinion. HTH
Zach
23
Jul 18, 2010 02:21 PM
redfin8288
Jun 4, 2010 08:06 PM
S2kRally
Nov 13, 2009 04:45 PM
24s2k7
Mar 4, 2009 06:50 AM
SuPer's2K@iVan
Mar 24, 2008 10:33 AM
