6-point harness install
Old May 14, 2009 | 05:14 PM
hondaf1's Avatar
Default 6-point harness install
more pics here - > http://gotspeed.110mb.com/2001_s2000_harness.php
Old May 14, 2009 | 05:21 PM
ideugene's Avatar
any reason you didnt use the harness bar?
Old May 14, 2009 | 05:52 PM
hondaf1's Avatar
harness bar is not in the ideal location, it's too high.
you can see this picture.
Old May 14, 2009 | 06:35 PM
mikegarrison's Avatar
IMO, anchoring harnesses to that sheet metal cross beam is a big mistake.
Much, much better to install a bar that has the harness bar in the correct location.
Old May 14, 2009 | 06:47 PM
Neutered Sputniks's Avatar
I would throw some washers on the rear bar...don't want the nuts pulling through the brace.
Old May 14, 2009 | 06:54 PM
hondaf1's Avatar
i was thinking of welding a bar from the back plate to the rear mounting plate of the roll bar for additional support.
Old May 14, 2009 | 06:57 PM
hondaf1's Avatar
i have grade 8 washers but i didn't use them because the plate is thick enough and the holes on the plate is the exact size of the bolt. i think the bolt would brake off before it pulls through the plate.
Old May 14, 2009 | 07:03 PM
Cool. The pics just make it look like the nuts are digging into that plate.
Old May 14, 2009 | 07:09 PM
I don't trust that beam period. But I've explained why before. You can search for it if you like.
Old May 14, 2009 | 07:21 PM
hondaf1's Avatar
could you post link, kinda hard to search on a vague topic.
i would think it's strong enough since the factory roll hoops are bolted to it.
