Old Feb 18, 2003 | 02:26 PM
Tedster's Avatar
Comptech is now selling an adjustable coilover set from
Old Feb 18, 2003 | 04:43 PM
pll's Avatar
pll
Rylan has a set. You can look at the ohlins site to get a little more info.
http://www.ohlins.com/pdf/productnews/hondas2000.pdf
You can find technical info on the MCJ shocks on the Ohlins site.
Naake Motorsports has this page, which has been up for a while:
http://www.naake.com/hondas2000.html
Old Feb 18, 2003 | 04:47 PM
lig's Avatar
lig
Max drop? hehe.. I can just see you now, Ted - 19's and slammed down to the ground scraping your way around the track but really blingin' hard!
Old Feb 18, 2003 | 07:39 PM
Tedster's Avatar
Jeff,
It's all about the bling, baby!
pll,
thanks for the links, I'll check those and fill in what info I get.
Rylan,
you out there? How are they?
Old Feb 18, 2003 | 08:18 PM
krazik's Avatar
Administrator
Spring rates are 308 ft/lbs & 365 ft/lbs rear.
High quality build with large pistons (almost as big as motons)
They soften up nicely for the street and get very stiff for the track. Each click is makes a nice linear difference in firmness.
0 clicks = full stiff to ~25 clicks to full soft. I drive on the street at about 16 which is a bit stiffer than stock.
I run the springs backwards using the 365s front and 308s rear keep which helps w/ real wheel lift and keeps the rear solidly planted.
At thunderhill I was running 0 clicks in the rear and 2 clicks in the front.
At Laguna I was running 2 clicks in the rear and 3 in the front.
My only complaint is that they are only single adjustable. But for 99.99999% of you, its more adjustablity than you need and the less "axis of control" the eaiser for the average go fast junkie to tune
-Ry
Each click controls the rebound rate mainly (and compression slightly).
Old Feb 19, 2003 | 01:30 PM
SilverSurfer's Avatar
Interesting you only have 25 clicks of adjustment...i believe i have 25 clicks on the rear and something like 50 clicks on the front. I drive 20 clicks front and rear on the streets.
Old Feb 19, 2003 | 01:32 PM
krazik's Avatar
Administrator
no there is no limit the # of clicks. The docs just say that if you unscrew too much you'll completely open the needle valve and be SOL.
So I've never gone past 25.
Old Feb 19, 2003 | 01:37 PM
WHAT A WUSS !!
Old Feb 19, 2003 | 01:42 PM
krazik's Avatar
Administrator
A wuss is someone who drives any higher than 20 clicks on the street.
Old Feb 19, 2003 | 11:27 PM
Tedster's Avatar
Rylan,
thanks for the review and info. Much appreciated. Keep us posted on how you like them as you do a few more events, and drive more street miles on 'em.
Thanks,
Ted
kleecker
Apr 26, 2011 08:57 AM
sambalam
Sep 27, 2010 09:30 PM
txs2knoah
Houstook Swap Meet
Apr 12, 2009 04:24 AM
Teutonic Machine
Jan 25, 2006 02:37 PM
Triple-H
Jan 20, 2006 02:41 PM
