Accusump EPC valve
Originally Posted by rlaifatt,May 9 2006, 08:03 PM
Funny they told me these valves rarely fail
is anyone here also using the one way check valve? I've run both with the check valve and without it - with the valve it drops maximum oil pressure 5 to 10 psi above 6k rpm.
I hear that if you plumb the accusump after the oil filter you can use the built in anti drain back feature of the filter. I T'd in the accusump before the filter and do not have this feature. plus oil that gets in the sump is unfiltered.
I replaced the $15 brass Canton check valve with the aluminum Earl's (for AN fittings) which is larger/better design that should be less restrictive, but costs like over $100.
I recall I bought mine here: http://www.anplumbing.com/shop/index.php?
But it should be available a any race shop, just Google.
