Active rear wing
Old Oct 9, 2008 | 12:33 PM
  #41
FormulaRedline's Avatar
Originally Posted by PedalFaster,Oct 8 2008, 09:17 PM
In theory that sounds reasonable, but in practice I've found that a balanced car with slightly less grip goes around a track faster than a very pushy car with slightly more grip. I don't know the physics behind this, so maybe someone else can chime in.
I'd agree with you that that tends to happen in practice. I think there are two effects at work here:
1) The driver is still driving the car like it's balanced. With a balanced car, it is going it's fastest when you push it right up to the limit. With an unbalanced car, by the time you get to the limit, it's too late. For instance, in our rear wing example, a driver who is used to having the whole car start to slide at once will wonder why the damn thing just won't turn in. In reality, the car is turning in as well or even better than before, but there is excess rear grip so it feels off. As a result, the driver tries thinks there should be more front grip, tries to turn more, and scrubs off speed.
2) The alignment is not considered. Adding a rear wing means the load on the rear end will now be dynamically changing with speed, while the front may not. For most vehicles, this means the camber on the rear wheels will also be changing with speed. If the car is still running the same rear camber it used to, then it will be too far positive relative to the previous setup. If the previous setup was optimized, this one will obviously not be. Additionally, if tires, springs, sway bars, or another modification has been made to add grip to the front and the front camber and caster are not changed, you'll run into a similiar problem there with the static settings.
As you say, these effects can make the car actually slower when there is only a small increase in grip. In cases where the increase is large, these effects may be masked. In either case however, these issues are costing time and should be addressed.
Old Oct 10, 2008 | 02:45 PM
  #42
FINAL GEAR's Avatar
sorry to say this was a 40 years old idea that was banned right away in all top professional racing league, due to high maintenance and error failure of the system, many teams can't figure out how to tune their suspension to work with this design, at the end it was just an old concept that did not work with any race car. Glad to see someone from MIT to bring this back after 40 years ! I hope it will work this time.
S2k007
Mar 27, 2012 11:22 AM
ytdlite
May 9, 2011 05:56 AM
Triple-H
Mar 11, 2009 04:50 AM
kakahoya
Oct 17, 2008 03:07 AM
Triple-H
Feb 13, 2008 05:09 AM
