Advice on Racing
Old May 4, 2004 | 04:00 AM
USCstudent's Avatar
Default Advice on Racing
Im kind of new to the clutch thing but I have picked up fast. Ive raced a couple of cars in my S but i feel i should be able to take off faster. Yesterday I raced a Lightning and won off the roll but lost from a stop. So ol wise ones give a newbie advice on how to launch so I can whop that guys ass next time.
p.s. need details like what i should do with the clutch and what i should rev to and what not.
Old May 4, 2004 | 04:12 AM
Saud2k's Avatar
mmm...
if your tires are ok...just drop the clutch at 6k rpm....you should take off fast enough
i never feathered the clutch...i never needed to anyways
just be careful out there
Old May 4, 2004 | 05:05 AM
Faysal's Avatar
I think ideal would be 4500 rpm -5000 rpm. Drop the clutch I think its the safest way to launch. Without much tire spin.
Old May 4, 2004 | 05:39 AM
glagola1's Avatar
Whatever you do, don't feather the clutch. It will just roast the thing. You have do drop the clutch for it to stick. That's my advice... besides the obvious fact that streetracing is gay and that you messed up when you bought an S instead of a camero. Torque ownz you foo!
Old May 4, 2004 | 05:51 AM
p0pe's Avatar
Take it to an autox or drag strip.. you'll have a lot more fun in a safer environment.
www.scca.org
Old May 4, 2004 | 06:02 AM
USCstudent's Avatar
Once again I would like to reiterate the fact I am new to the whole clutch thing so I am just now catching onto the lingo. So if it would not be too much trouble I would like to know what feather and dropping the are.
Forgive me for my igorance
Old May 4, 2004 | 06:11 AM
p0pe's Avatar
Feather is to ease off the clutch pedal
Drop is to suddenly release the clutch pedal
Feathering can be dangerous when launching at high RPMs because you can 'glaze' your clutch disc. Basically, the clutch disc isn't pressed all the way against the flywheel and has room to slip, which causes a lot of heat and can fry the clutch disc.
When dumping it your assured that the pressure plate is applying maximum force on the clutch disc to the flywheel. However, dumping it will cause more stress on other components of the drivetrain (the driveshaft, rear end, & axles).
Old May 4, 2004 | 06:51 AM
Ace10's Avatar
if you're new to the "clutch thing", then why not attain some substantial driving experience with the flow of traffic and by observing normal rules of the road before you try to become joe-stoplight-dragracer?
i'm being serious here. if you are unfamiliar with how to operate a vehicle with a clutch, please don't try to drive your car beyond YOUR capabilities. the rear end will step out on you like a common street hoar if given too much throttle or using too little technique with the clutch.
$0.02
Old May 4, 2004 | 08:51 AM
USCstudent's Avatar
Ok ive studied up a little and I figure it would be best to take the car to the track and learn there. However, I have a few lingo related questions left. What is dumping and slipping the clutch and how do you do these things. I have a general idea but I figure knowing for sure is the best way.
Old May 4, 2004 | 09:11 AM
SS4Gogeta's Avatar
Dumping the clutch is the same as dropping the clutch. Slipping refers to the clutch disc not truly engaging the flywheel which causes heat build, wear, and tear.
