advice wheel sizes
Old Nov 12, 2011 | 09:32 AM
harrys's Avatar
Default advice wheel sizes
Have a question re. wheels for my race s2000, in particular ET value for following set-up:
starting points:
- overfenders at the rear (while slightly cut-out oem fenders)
- frontfenders , plastic type, 10 mm each side wider, compared to OEM
- camber front and rear each corner -/- 4,0 dgr.
- requires wheel and tire dimensions all 4 exactly the same (duely ease of changing race tyres frnt to back v.v.)
- so, want to install (4*) 17 * 9 wheels at a single ET value
- no use of spacers
- it's all about handling
What ET value /offeset (or min-max range for ET) would you recommend for this set up. It 's all about handling.
Thanks,
Harry from the Netherlands.
Old Nov 12, 2011 | 12:58 PM
aCab's Avatar
Hey Harry,
You should be able to run a 17x9 +35 quite easily with those fenders and camber. you may even look into a +30 or so or even less.
Old Nov 12, 2011 | 03:31 PM
clarkster009's Avatar
^I dont know about that. Maybe in the rear with overfenders, but not with 10mm front fenders.
A popular size with stock fenders is 17x9 +63. If you are running 25mm rear overfenders, you should run wider front fenders than only 10mm. If you get 25mm fenders for the front, probably a good size would be 17x9 +40.
Old Nov 12, 2011 | 07:07 PM
robrob's Avatar
17x9 +45 is a popular size. I run a set with Hoosiers 245 width. My fenders are rolled and the rear fender tab is relocated. I get the standard front fender liner rubbing.
Old Nov 13, 2011 | 02:33 AM
harrys's Avatar
Thanks folkes.
Further advice appreciated .
Forgot few things to mention, may be relevant for clearance issues :
- I run Stoptech BBK at the front (rear is oem ).
- And I did throw away the fender inner liners.
- now fitted, depending from event / track wheater circumstances either ( each corner of car exactly the same) :
a/ Nismo 17 * 7,5 , ET 45 , spacer: 25 mm ( Michelin slicks 20/61/17)
b/ Buddy Club 17 * 7 , ET 42, spacer 25 mm ( Michelin full wets 20/61/17)
c/ Buddy Club 17 * 7 , ET 42, spacer 25 mm ( Toyo R888 215/45/17)
With car set up as initialy mentioned, lots of space left duely rear overfenders, at front alsmost no space left
So, going back to my desired all round 17*9, any new advice on ET/offset ?
Thanks again.
Harry
Old Nov 13, 2011 | 02:39 PM
CKit's Avatar
I'd think anything in the +42 to 52 range would work well. +62 / 63 would possibly put you in the shock bodies or A-Arms with that much camber.
+30s is too low for the fenders you're running (probably).
Old Nov 13, 2011 | 03:41 PM
markhs2's Avatar
What brand, model and size tire will you be running on the car?
If it's all about handling why do you want to run a 17x9 wheel? why not 17x9.5 or 17x10?
This is important and I don't see it listed.
Old Nov 13, 2011 | 05:03 PM
CKit's Avatar
Above, he's currently running Michelin slicks.
If he's on a stock motor, I'd think a 17x9 with 265 or 275 full R-comps would be a sweet spot of grip to weight / rolling resistance.
Old Nov 13, 2011 | 10:40 PM
c32b's Avatar
currently on stock fenders front and rear. rolled to the max with a very slight flare for the rear and relocated rear tab. I rub my front liners when I go close to full lock.
Running 3.0 deg F & R with 255/40/17 on 9J, ET +45. Slight rubbing on big dips so need to do a bit more flaring for the front & rear.
hope this helps.
Old Nov 14, 2011 | 04:20 AM
harrys's Avatar
Like to respond to some new issues you are throwing up guys;
./ not stock engine, it's running on ITB's
./ upper arms ( front and rear) are IKEYA
./ shockabsorbers are Moton Clubsport
Any more advice for the right ET choise ?
Thanks,
Harry
