alignment arms bent. need alignment advice
Hey guys
My front right wheel cannot gain any negative camber. its maximum camber allows to sit on 0 degrees. All my other wheels are fine tho.
The course I am going to is mainly a right hand turn course but still has a few left handers.
I am running a completely stock setup with semi slick rubber and was wondering what settings should I dial into my alignment? Should I go minus 1.75 degrees on the front left wheel and 0 on the front right or have both fronts equal to 0?
Thanks,
Thanks,
Fix your suspension by Saturday or don't go. Seriously. If that sucker breaks, you could total the car and/or kill yourself. You might even be able to get your money back for the track event if they have a wait list they can fill from. But if not, oh well.
This is what technical inspections are for.
It's likely the lower arm that's bent and need replacing. I don't think the arm can break easily, but I would check all the suspension parts, including the brackets to make sure they are not broken. I would go with equal camber (0 if necessary).
Also, Honda is moving to an overnight ordering system for all of their parts. They are phasing it in regionally, so at least here in the states you might be able to have the dealer order the part and have it for you the next day.
Just another option.
