Alignment Method
Old Jun 19, 2007 | 07:32 AM
zo7vette's Avatar
Default Alignment Method
I am going to have my AP2 aligned here at work, an automotive dealership, and needed to know how the S is aligned. Does it use eccentric bolts or does it need shims? Can a qualified technician from another brand align this car?
This will be an SCCA Solo AS alignment. I am planning on max front camber, zero toe, -2.25 rear camber and just shy of 1/4" toe-in.
Jeff Cawthorne
Old Jun 19, 2007 | 07:37 AM
Ludedude's Avatar
Administrator
It uses eccentrics. Any competent alignment tech can do it, but there's a learning curve involved, especially in the front, where all the adjustments interact with each other.
Old Jun 20, 2007 | 07:09 AM
zo7vette's Avatar
Thank you Ludedude. The tech I will be using takes care of the owners race cars, and is very good. He did the alignment on my other AS car
Jeff
Old Jun 20, 2007 | 03:20 PM
Ludedude's Avatar
Administrator
Then you should be in good hands
You might rethink that rear toe number; I'd try going with something closer to 1/8" total toe in the rear, especially with the improved rear suspension geometry of the AP2 chassis.
muha22752
Aug 24, 2012 02:10 PM
SPLNDID
Mar 14, 2010 02:19 PM
Black Knight
Feb 6, 2010 12:12 PM
