alignment numbers? for autoX?
Old Aug 30, 2006 | 02:30 AM
kfdon's Avatar
Default alignment numbers? for autoX?
i'm running stock tires right now, but
i'm going to use 245/45/16 for my rear and. 225 something for the front?
my aligntment is off right now after changing tranny?
any recommendations for alignments? for better traction?
going to go autoX and hope track soon,<< when i get some money back
those numbers good for daily driving too or should i change it back?
thx
Don
Old Aug 30, 2006 | 03:52 AM
jguerdat's Avatar
Didja read the stickies? Lotsa good info there.
I wouldn't think you'd need to realign after a transmission removal - it has nothing to do with the suspension.
Use the U.K. specs if you want to kepe treadwear to a minimum. Alternatively, make sure the front has 0 toe - you should be able to live with the camber. Swap tires inside out to even out the wear...
Old Aug 30, 2006 | 08:28 AM
AlwaysTopless's Avatar
sound advice
P.S. Removing the tranny will not effect your alignment..
Top_down
Dec 22, 2014 06:43 PM
johngamez
Dec 30, 2012 01:59 PM
chris2002
20
May 5, 2007 05:27 AM
Dave04
Jul 31, 2006 07:07 PM
Cragspider
Apr 29, 2005 11:40 AM
