Alignment Question
Old Jun 11, 2004 | 07:22 PM
S2Thizzle's Avatar
Default Alignment Question
I had an alignment done at Roger Kraus Racing last October and I've done about 7-8 HPDEs since then. Today I noticed the left-front tire is wearing on the inside much more than the right-front tire's inside. The rears are fine. I'm wondering if I could've knocked the alignment out of spec running over the berms (sp?) on the track - I usually try to run over every flat/semi-flat one. My question is, should I be doing an alignment regularly since I'm tracking the car quite often (at least once or twice a month now)?
Old Jun 11, 2004 | 08:37 PM
davepk's Avatar
I usually get an alignment about 2 times a year. If i've had a bad off then i may get it checked and corrected then as well.
You need to make sure they really crank down on the adjustment nuts to keep it from changing easily.
Old Jun 12, 2004 | 12:35 PM
S2Thizzle's Avatar
[QUOTE]Originally posted by davepk
candyteggy
Mar 1, 2010 04:58 PM
Hero
Apr 2, 2008 12:08 PM
G2k
Feb 11, 2007 02:12 PM
madkimchi
Sep 11, 2005 06:19 AM
