View Poll Results: car drives straight. What would happen if I adjust my front right tie rod in (shorter).
car would pull to the left
8.00%
car would pull to the right
8.00%
steering wheel would be off center to the left and car would pull one way
4.00%
steering wheel would be off center to the right and car would pull one way
20.00%
car would drive straight with toe in and an off center steering wheel
48.00%
car would drive straight with toe out and an off center steering wheel
12.00%
Voters: 25. You may not vote on this poll
Alignment question
Old May 15, 2007 | 10:02 AM
rlaifatt's Avatar
Only 2 people got it right so far .
Old May 15, 2007 | 11:50 AM
Orthonormal's Avatar
Does the steering rod connect behind the ball joints then? That would change my answer from #5 to #6.
Old May 15, 2007 | 02:14 PM
macr88's Avatar
Our tie rod is in the front unlike my high performance Camry. Hahaha
Old May 15, 2007 | 02:34 PM
Suspension's Avatar
Orthonormal, why does that matter? I don't think it should. He made a toe in change. Toe in is toe in no matter where the steering link is. Maybe you were thinking he "shortened" the steering link?
But Mac, what you really want to know is if this change will cause the car will pull to one side, right?
Old May 15, 2007 | 02:51 PM
macr88's Avatar
I don't think I said toe in?.
Yes that is my question.
Old May 15, 2007 | 03:10 PM
macr88's Avatar
Hahaha ooops my bad. I wasn't supposed to say toe in.
Old May 15, 2007 | 03:14 PM
macr88's Avatar
double post.
Old May 15, 2007 | 04:14 PM
Well, the poll question was "What would happen if I adjust my front right tie rod in (shorter)." I didn't look at the text of the post where he said "toe in".
Shortening the tie rod (moving the end in) will create toe-in if the rod connects in front of the ball joints, toe-out if it connects behind. I thought that the rod connects in front, but rlaifatt claimed that "only 2 people have the right answer so far" (which at the time indicated answer #6). So I wondered if I hadn't really gotten a good look at the suspension when I had the shocks out on Saturday.
The car won't pull to the side due to toe, in either case.
Old May 15, 2007 | 05:04 PM
rlaifatt's Avatar
I voted 4 . Just my opinion.
Old May 15, 2007 | 05:16 PM
Suspension's Avatar
Ah yes, I didn't notice the text above the poll. We're even. I understand.
