Alignment specs
Getting Bridgestone RE 11 255/40/17 square setup. Tires are for streets mostly with a few trackdays a year.
What alignment specs (camber, toe, caster) should I be running on?
Depends on a lot of stuff. This is a big YMMV. One size does not fit all.
Your skill level will also play a big part of how much "forgiveness" you need to keep in the alignment settings.
A track alignment will make compromises on the street. A street alignment will make compromises on track.
The question is also impossible to answer without bar / spring information.
