Another Alignment Question
Old Feb 16, 2006 | 04:08 PM
NFRS2K3's Avatar
Default Another Alignment Question
I am looking to find out a good alignment spec for my car. The car will be driven 95% of the time on the street (like an animal) and then I also plan on attending a few track days at some point as well this summer (Not AutoX). I am looking for a good compromise between even tire ware and good high speed stability without understeering into the weeds.
Here is my setup:
H&R Coil-Overs (Spring Rates=345lb Front & Rear)
The vehicle will be lowered approx 1-1.25" Max (This will be dependant on what ever the ideal corner weight numbers end up being)
I also purchased the BSK from GoFast Labs
I will be running 17" Volk CE-28n wheels:
17 x 7.5 Front Offset is 50 using 225x45 tires (Michelin Pilot Sport II's)
17 x 9 Rear Offset is 63 using 255x40 tires (Michelin Pilot Sport II's)
Stock Front & Rear Sway Bars
I have done quite a bit of searching on various alignment specs with and without the BSK installed but it's hard to tell if these specs I am finding are mostly for track dedicated cars.
From what I have found the OEM Specs appear to be:
Front Castor: 6.0
Old Feb 16, 2006 | 06:18 PM
Ludedude's Avatar
Administrator
I'd do a search for the fabled "UK aligment" and go with that especially if the car is going to be 95% street driven.
Old Feb 16, 2006 | 06:35 PM
SC_Highlander's Avatar
I have the BSK and KW coilovers. I've been running the following since last fall:
Front: 5.5 deg caster, -1.5deg camber, 0 toe
Rear: -2 deg camber, 1/8th inch toe in
Old Feb 16, 2006 | 07:22 PM
CosmosMpower's Avatar
[QUOTE=SC_Highlander,Feb 16 2006, 07:35 PM]I have the BSK and KW coilovers.
Old Feb 17, 2006 | 03:49 PM
NFRS2K3's Avatar
Thanks for the replies, It's much appreciated.
Old Feb 20, 2006 | 11:42 AM
teamking's Avatar
[QUOTE=NFRS2K3,Feb 16 2006, 08:08 PM] From what I have found the OEM Specs appear to be:
Front Castor: 6.0
Old Feb 20, 2006 | 11:51 AM
[QUOTE=teamking,Feb 20 2006, 12:42 PM]
Also, the UK camber spec is 6
Old Feb 20, 2006 | 11:58 AM
teamking's Avatar
Originally Posted by CosmosMpower,Feb 20 2006, 03:51 PM
6+ Degrees of negative camber?
Ha!!! I'm a real saint with my attempts to clear up the confusion!
6.75
Old Feb 20, 2006 | 03:33 PM
NFRS2K3's Avatar
Thanks for clearing that up
Old Feb 20, 2006 | 09:42 PM
Bassem's Avatar
Someone had posted a jpg image of this (I have on my computer) but I can't show it (I'm guessing because I'm not a member). I'll be happy to email it to someone who is and they can post it. PM with your email if you want.
The "optimum spec" as listed on Bulletin A0002294 is:
Front:
Caster 6.45 (really its maximum equal 90% of cars can't get this high)
Camber -1.0 deg.
Toe 0.0 deg.
Rear:
Camber -2.0 deg.
Toe 20 seconds (1/3 of a degree)
Bassem
