Anyone swap to later ECU in AP1?
Originally Posted by sirbunz' timestamp='1404940447' post='23236824
[quote name='s2000Junky' timestamp='1404939230' post='23236794']
Swapping the ecu isnt worth crap, all the benefit comes from being able to lower vtec to gain a broader power band and the added benefit of smoothing out the "hit" for a more predictable/smoother trq curve. This is important on the track, and appealing on the street. You need a Test pipe though to take full advantage of this, allowing you to start picking up power as low as 3500rpm, otherwise with the stock cat you won’t see any gains until about 5300rpm.
Here this might be helpful
https://www.s2ki.com/s2000/topic/109...ning-solution/
-Marc
[/quote]
Maybe you missed this...
If you are referring to converting to AP1v2 (02-03) ECU, there is improved tuning and added fuel over the earlier AP1 ECUs. I still wouldn't trust my car with it on a track and would want the security of a more advanced unit since mods to the airflow this car shows changes in the A/F using data from my local tuners and their experiences with s2000s.
-Marc
-Marc
Sorry you feel my info was "left field," but it just might help someone who needs it though and I feel relevant. As for 75% this or 80% that , I have no clue how you calculated this. The stock S2000 is not track reliable. It will work, but I and some other local S2000 drivers have no problem overheating well prepared ones. I have seen many that have thrown a motor due to the reasons I mentioned. Despite this, in simplest/cheapest form, no ... you do not have to do anything to your car in order to track your s2000 except pass inspection. No worries though, you are right depending on how you wish to look at the topic.
-Marc
Sounds about right above 8k. My '03 stock was approx 12.2 at 8100 using a sniffer combined/compared with my Haltech wideband. Both ap1 ecus look like they go really rich at the top end.
EDIT ... 3kish and 6k ish are where the mixture raised my eyebrow. 5-6k always seems a mess. With mods, it gets worse. A simple CT CAI made both mentioned points jump over 14.
Go with the Neo, you can adjust every 500rpms and also adjust vtec engagement based on % throttle, so it isn't noticeable off the track. There are also many other features that I am forgetting. Watch the boards and sometimes you can get the Neo and harness at a good value.
Coming from my last tuned car running with full kpro I was a bit reluctant to go with the Neo, hearing claims that you can't add fuel and that you ECU can override the tune. I talked with the shop I use, who I intrust with any and every car I have owned and he basically said all of that was total b.s. So I guess we will see how everything works out for me. The only other option for me was kpro and that is a $2k investment for maybe 5-10whp
OP, I only suggest ems as your other option because I thought you were dead set on not using it. Before I went kpro, I used a vafc2 with boomslang harness and enjoyed it. As stated above, you would want to have a test pipe with either options. Understand you can only subtract fuel and NOT add fuel with a piggybacks(neo,vafc, vafc2)
VAFC 'tuning' is only for open loop (WOT) so don't worry about trying to tune closed loop.
You will need an AFR sensor to due any sort of tuning unless you rent a dyno that has a tail pipe sensor.
You can get an ODB2 bluetooth connector to your smart phone and observe how you are affecting engine timing by cutting fuel with a VAFC.
I suggest just get the VAFC and only drop VTEC, dont bother with the fuel tuning yourself unless you really know what you are doing. Dropping VTEC will give you the midrange bump you originally asked for.
Originally Posted by s2000ellier' timestamp='1404957277' post='23237224
My 01 runs low 12s AFR above 8000, not lean by any stretch
When you lower vtec of course you will run leaner, the ecu still thinks its running in primary cam and delivering that amount of fuel. This area from the new lowered vtec to the stock engagement is where the rev band will show the first signs of fuel enrichment needed, IF the current MY ecu and bolt on config isnt pig rich to begin with, sometimes the primary cam fueling is adequate for the modified engagement without any additional fuel required. I found this to be more of a case with the early ap1's. Never the less, an onboard wideband is the best way to know where your at, tune appropriately.
Yes that will be fine, considering your MY ecu and vtec lowering point. From 5-6k its a bit of a flat/dead zone and where the stock fueling runs rich, now if you were to lower beyond 5k id say start thinking about checking your afr and potentially getting some fuel enrichment depending on how your motor is breathing with any bolt ons, 4500rpm is a sweet spot and shows the most gains and naturally the most fuel would be needed there. 3500 - 6k is the typical vtec improvement point with TP, and from 4k to 4500 is where the mid range power peaks. From 5-6 k you’re getting some bump in power, but its not as significant as the previous 1000 rpm.
