Anyone using karting neck brace?
the foam collars are mostly to help support your head.. its not going to keep your neck from over extending. i just started using a simpson rage pro harness.. its a little more comfortable than a hans unless you go with the cf version..
Not if your goal (as stated in your first post) is to prevent a basal skull fracture in a crash. Foam neck collars aren't designed to do that -- they're just intended to help support your neck in a long race, as it might otherwise get tired from the g-forces.
