AP1 Autox alignment...FAQ still accurate?
Old Aug 23, 2006 | 09:46 AM
WarrenW's Avatar
Default AP1 Autox alignment...FAQ still accurate?
The alignment for an AP1 autox set up in the FAQ are listed as:
Front toe - 0" to 1/8" toe out
Front camber - -1.5 to -1.75 degrees
Rear toe - 1/4" to 3/8" toe in
Rear camber - -2.0 to -2.25 degrees
Are these still the preferred settings for autoxing? It's time for another alignment for me so I thought I should ask. I'm running Hoosier A6 (225's all the way around), Saner bar on the middle setting and Koni Yellows.
Warren
Old Aug 23, 2006 | 11:11 AM
Conedodger's Avatar
Those numbers work well for me. I would avoid toe-out in the front though. It'll really chew up your street tires, and the S turns in so well that I don't think you need it. (Unless you find yourself in the top 5 at Nationals. lol)
I believe this alignment spec was with a staggered tire setup and a stiffer swaybar setting 'though. I would think same size tires and a soft sway bar setting like you have would be a real handful.
Bama Dave
May 20, 2015 10:23 PM
rednikos
Apr 5, 2015 03:57 PM
dsddcd
Mar 15, 2012 05:35 PM
E-Z
Jun 2, 2007 12:57 PM
