AP1 in BS: Square 245 or stagger?
Old Jan 25, 2011 | 04:45 AM
  #21
pinkertonpunk's Avatar
Matt, I think we ended up running the next solid size up from 1.25" solid bar. Don't remember the exact size though.
Old Jan 25, 2011 | 06:00 AM
  #22
TheNick's Avatar
Originally Posted by Zeus2k,Jan 24 2011, 08:33 PM
pretty sure he has penskes /doublelurk
No Moton's or Penske's. The Penske's are on a car in Philly now.
Currently just have the Bilstein's that came with the car.
Old Jan 25, 2011 | 08:15 AM
  #23
Kaolinte's Avatar
Originally Posted by glagola1,Jan 25 2011, 08:28 AM
Awe crap, I already ordered the 1.25" hollow bar. Is that too small?
Jason, what happened to the XP car?
Matt,
It is getting a new cage and suspension bits that may not be complete in time. I hope to have it complete, but need to have a contingency plan in place.
Old Jan 25, 2011 | 08:18 AM
  #24
Kaolinte's Avatar
With your smooth driving style, you would likely be able to run a 1.25" solid bar. I did with very little inside wheel spin.
Old Jan 25, 2011 | 08:33 AM
  #25
josh7owens's Avatar
for b-stock and for some in str thats too soft. You want the 1.25 solid bar on full stiff or the 1.375 bar on one of the middle settings. Talk to marc about it.
Old Jan 25, 2011 | 01:21 PM
  #26
glagola1's Avatar
FWIW, the 1.25 hollow bar was way too much for my STR car on stiff or even one off stiff.
I think I'll give it a go and if it's no good, I'll order the other middle section.
Old Jan 25, 2011 | 02:35 PM
  #27
sirbunz's Avatar
With an AP1 in stock class prep, its nice to have options. Seems the AP1s kept going stiffer and stiffer on the sway bars considering the soft front spring rates. I run the 1.375 set at 50% (3/6) on the CR, so in general, an AP1 will need to be higher for a similar effect.
Matt, I'm sure the 1.25 will be fine to start with. Sounds like a good plan! For future reference, daverx7 has all the info on changing out the center section.
See you at Dixie!
-Marc
Old Jan 25, 2011 | 02:54 PM
  #28
CKit's Avatar
Have we ever had an s2ki thread with 4 National Champions posting in it?! Holy carp.
Old Jan 25, 2011 | 11:58 PM
  #29
mLeach's Avatar
Get those front arm mounts welded before you pull them out.
Old Jan 26, 2011 | 05:41 PM
  #30
glagola1's Avatar
Awe Matt, it took a couple years to tear them. I'll put it off until I move back to civilization.
