AP2 Brake Ducts
Old Mar 30, 2013 | 09:09 AM
  #211
boyguan's Avatar
Did you also check on wheel full lock to lock
Doesn't look like their is much give for that
I wonder if you can adapter the rear duct connector to the front
Old Mar 30, 2013 | 09:16 AM
  #212
slowd16's Avatar
Kraft, is the ducting touching the abs wheel sensor in the 3rd pic down? Looks like it would rub right through if it is.
Old Mar 31, 2013 | 12:31 AM
  #213
kraft's Avatar
Originally Posted by robrob
John, would you be willing to tape one side up and take some rotor and caliper temp readings? That looks like an elegant setup but i'd be nice to confirm its function. Also some detail of the intake mounting would be cool.
Thanks Rob thats a good ide, I vill tape one side up when I go to the track next time, and take some temp readings.
Old Mar 31, 2013 | 12:34 AM
  #214
kraft's Avatar
Yes I did check lock to lock and it's no rubbing och problem.
It looks really tight on the pictures but its not that bad irl
Old Mar 31, 2013 | 03:35 AM
  #215
s2kt3's Avatar
Doesn't cooling only one side of the rotor cause the rotor to crack ???? That worries me!!!
Old Mar 31, 2013 | 06:21 AM
  #216
robrob's Avatar
Most of the airflow from the ducts gets pumped from the inside of the disk through the disk and out the outside edge.
Old Apr 12, 2013 | 10:50 AM
  #217
WASPcomposite's Avatar
Banned
Greetings all,
AP2 Brake ducts are finally done and ready for shipment. here are some pictures, to order please click HERE
- Fits AP2 front bumper
- Accepts 2.5" tubing
- Easy installation, no screws necessary for a clean look.
- Clears Air pump on driver side
Thanks,
WASP
Old Apr 12, 2013 | 08:27 PM
  #218
andrewhake's Avatar
Awesome! What exactly is the install process? Epoxy? Or some sticky double sides tape? Looks great!
Old Apr 12, 2013 | 09:11 PM
  #219
mas2kap1's Avatar
I bought the orange duct and the aluminum flange from that aerospace website.
I just need the piece to attach to the front bumper. I have an AP1, so the WASP one wont work.. ($175 is a bit too much..)
I know its ghetto, but has anyone tried just cutting out the plastic, and a couple of holes around it for some good old plastic zip ties??
Old Apr 12, 2013 | 09:42 PM
  #220
andrewhake's Avatar
I am planning on doing the WASP ducts, but decided to play around with different styles of duct covering. My first though was just cut slats into the current plastic cover to keep the OEM look. Thought I would share. It is a really minor thing but I can't stand looking at hacked together crap.
(view images at original size to see the difference)
v01 (removing every other slat):
v02 (removing half of every slat, similar to the size of the hole that is in the cover already):
or v03 (Evo IX mesh material, removing the cover all together) Probably the best option in terms of airflow, and doesn't look bad at all.
