Auto-X: Recommended alignment specs for my setup?
Old Jun 14, 2007 | 05:08 PM
ConeKiller's Avatar
Default Auto-X: Recommended alignment specs for my setup?
I'll be mounting 245/45/17 (front) Kumho V710's and 275/40/17 (rears) on my AP2 wheels. I have a '06 S2000 with Front comptech adjustable racing sway bar, version 2 (on softest setting).
What alignment specs would you recommend for my setup? (For auto-xing)
Thanks,
Brian
Old Jun 14, 2007 | 05:41 PM
Suspension's Avatar
Click here
Old Jun 18, 2007 | 03:00 PM
Zero Bar's Avatar
^^That only gives specs for the AP1 and suggestions for the AP2.
Here's what I'm running that has worked well so far.
-1.5 Front Camber
5.9 Caster
0.0 Toe
-2.0 Rear Camber
+.19 Toe
The car has stellar turn in but peak corner is lacking a little. After our Evo school we noticed extra wear on the outside of the front tires(we used street tires for this). Even with the toe slightly out the car is very stable.
We plan on going to -1.8 camber up front maybe a touch more and -2.2 in the rear. This is on an 06' with stock wheels, 245/275 wide Hoosier A6's, KW coilovers and Gendron front swaybar.
Hope that helps, it's all trial and error.
Old Jun 18, 2007 | 08:42 PM
sirbunz's Avatar
Here are some from my last two seasons. I prefer the '07 settings for my driving style. Good Luck!
2005 Honda S2000 Alignment Specs.
2006 2007
Camber: Left F -1.26 -1.41
Right F -1.35 -1.46
Left R -2.48 -2.51
Right R -2.54 -2.55
Caster: Left 5.36 5.09
Right 5.64 5.35
Toe: Left -0.03 -0.07
Right -0.05 -0.06
Left R -0.06 -0.09
Right R -0.1 -0.07
Cross Camber F: 0.09 0.05
Cross Caster F: -0.28 -0.26
Total Toe F: -0.07 -0.13
Total Toe R: -0.16 -0.16
Thrust Angle R: -0.02 -0.01
Jason Saini
Front: Camber: -1.5
Old Jun 19, 2007 | 02:16 PM
Orthonormal's Avatar
Set the front bar to the stiffest setting.
Front camber: Max negative (I got -1.6)
Front caster: 6-7 degrees, whatever results from the max camber setting.
Front toe: 1/16" toe out
Rear camber: Slightly more than front (I use -1.8 to -1.9)
Rear toe: zero
That's what worked for me with those tires and the solid Gendron bar set at the stiffest setting.
Old Jun 23, 2007 | 09:41 PM
ConeKiller's Avatar
Thanks for the responses! Helped a ton Had my alignment done today. Car feels like it handles much better. Auto-x tomorrow will be a better test
Here are the specs I got:
Camber: Left F -1.8
Right F -1.9
Left R -2.3
Right R -2.5
Caster: Left 5.8
Right 6.1
Toe: Left - .02
Right -.05
Left R -.02
Right R -.03
Cross Camber F: .1
Cross Caster F: -.3
Total Toe F: -.06
Total Toe R: -.05
Thrust Angle R: .01
Old Jun 24, 2007 | 06:08 AM
Zero Bar's Avatar
Camber: Left F -1.8
Right F -1.9
Left R -2.3
Right R -2.5
Caster: Left 5.8
Right 6.1
Toe: Left - .02
Right -.05
Left R -.02
Right R -.03
Cross Camber F: .1
Cross Caster F: -.3
Total Toe F: -.06
Total Toe R: -.05
Thrust Angle R: .01
Who do you have do your alignment? They should be able to match everything up from side to side if they do it right. I stumbled on a guy at a local NTB that is scarily good at it so it can be hit or miss with that.
Old Jun 25, 2007 | 10:48 AM
E-Z's Avatar
E-Z
I agree!!! If you're going to pay for something, they should do it exact. The s2k isn't very hard to align. It isn't rocket science.
I gave my mechanic my specs, and this is what he did for me.
Old Jun 25, 2007 | 07:19 PM
sirbunz's Avatar
A tad bit harder than you think to get it down to a tenth. If you are within .2 of your desired settings you will be fine. Most custom alignments shoould be within a tenth from an expirianced tech.
Old Jun 26, 2007 | 05:48 AM
E-Z's Avatar
E-Z
Don't confuse being difficult with being lazy. I was in the bay with the tech the entire time he was doing it. Didn't look too hard to me. Caster adjustment is the only thing that takes any amount of time because you have to adjust, then recenter, adjust, recenter, etc....
All eccentric bolts/bushings make it fairly easy and took all of 30~ minutes.
