Auto-X tire question
So my wheels are 18x9 fronts and 18x10 rears.
I basicly have 2 DOT options in the sizes I need (~245 front, ~285 rear). Hooisers and Kumho Esctas.
While I'd like the extra stick of the Hooisers I am leaning towards shaved Esctas as I can use them for "street" tires too the 1 day a month my car -might- see street driving.
Are they Esctas signficantly slower at auto-x? Should I just buy the hooisers?
Also Auto-X is 99% of the time on concrete.
Ry, I didn't run on full shaved Ecsta's, but they were heatcycled and driven on the track 1 day. Not that I can compare both, since I have never actually driven on Hoosiers, but rzrsedg's car felt WAY more glued to the ground. If you are going for a competitive time and not just a fun run, I would say Hoosiers.
Just get the Hoosiers. I haven't heard great things about the Ecstas in those sizes. For how often you'll street-drive your car, you could probably get away with not changing them. I know a few people who do it all the time.
Make sure to get A-compound as well. You won't be able to get enough heat into the R's.
Rylan,
I don't think the Ecstas work all that great when stuffed on a wheel that is too narrow, and need good negative camber (not sure what you are running). With your wheel sizes, you shouldn't have a problem with stuffing, but I'm not sure the 225F/285R combo would work well (depends on the rest of the setup whether it will push badly). The 265F/285R combo would be better and should fit fine on your wheels, but it might not clear in the front. Hoosier 245/285 would be faster autoxing and fit, but I wouldn't drive them on the street much.
So I'd think that....
-The Hoosiers will certainly be faster at autox. Not by a ton, but they should be consistently ahead esp. on concrete.
-The Ecstas will be a far better street tire.
-The better Ecsta setup (265F) might not fit, anyway.
-Andy
-Andy
Here I am! (Krazik asked that I reply to this)
I agree wholeheartedly with Mr. McKee.
Andy (along with Derek) are the only autocrossers (that I know) that are SERIOUS enough to have done a tire test. Back to back at one test-n-tune event Andy and Derek tested each tire on the market to determine which tire was the fastest. They even ran the tire expected to be slowest last - to remove the "learning the course" variable. The test was a while ago - but I believe the results were: 1) Hoosier A compound, 2) G-Force, 3) Kumho Victo V700. I think it was on concrete. I only really remember that the Hoosier won...
(Did you see the thread dedicated to me Mr. Andy? Did ya? I always look fast when you don't show up.)
-Sean
-Sean
Ry you may know this already but Hoosiers run wider than their advertised number width (i.e 265 may be closer to 275 or so). I believe they have the actual widths listed online, so make sure you check before you buy.
bassem
bassem
