Autocross Alignment Questions
Old Nov 24, 2003 | 03:45 PM
Windscreen's Avatar
Originally posted by davepk
Just to verify, we are talking about the rearmost bushing of the rear lower A-Arm, correct?
Yup!
Old Nov 25, 2003 | 06:49 PM
slick's Avatar
[QUOTE]Originally posted by Hyper-X
First of all, I'm in BS.
The only major mod I've done with the car is R compound tires on OEM wheels.
Old Nov 28, 2003 | 01:09 AM
Hyper-X's Avatar
The sidewalls of the Victoracers do seem softer than S02's for example. I'm planning to try out UK alignment specs to see if I can achieve more effective cornering force in hopes of shaving off a full second, maybe.
Another mod that I'm planning to implement is the Saner front sway bar to help settle things down a bit.
Thanks for everyone's input!
Old Nov 29, 2003 | 04:19 AM
vapors2k's Avatar
have you experimented with air pressures?
Old Nov 29, 2003 | 06:33 AM
Hyper-X's Avatar
Yes. Altering tire pressures is my single, most important tuning approach for the past autocross events. I've purchased a pyrometer and carefully monitored the temperatures of the tires immediately after each run. While I've made small changes after each run, I've found that there's a limit to how much grip can be had using my Victoracers and unfortunately, I think I'm only using about 75% of the potential due to the wear pattern.
From what experienced drivers have told me, I'll need to run more camber eventually in order to maximize the R compounds. My only issue with that is my car is my daily driver so I'd like also maximize tire wear on my S02's. I may give the UK alignment specs a shot.
Old Nov 29, 2003 | 01:23 PM
slick's Avatar
99SH
Dec 13, 2010 07:56 AM
SteveUCI
Feb 26, 2006 09:07 PM
xtinkt
Aug 13, 2005 05:59 AM
Cragspider
Apr 29, 2005 11:40 AM
MarvinB.
Mar 11, 2002 06:42 AM
