Autocrossing the S
Old Oct 9, 2005 | 12:27 PM
2QYK4U's Avatar
Default Autocrossing the S
I read the autocross FAQ article, which is probably the best article I have read thus far . The article didn't discuss performance modifications such as:
1. Front strut tower bar
2. Rear strut tower bar
3. Front x-brace
4. Rear lower tie bar
5. Floor bar / chassis reinforcement
Did the article intentionally ignore these modifications because its focus was on modifications that still allow the S to participate in A-Stock, or because these modifications offer little benefit?
Any and all feedback is greatly appreciated.
Old Oct 9, 2005 | 01:36 PM
payneinthe's Avatar
Yes!
What makes you think any of these are "performance modifications"?
Old Oct 9, 2005 | 01:46 PM
2QYK4U's Avatar
Originally Posted by payneinthe,Oct 9 2005, 02:36 PM
Yes!
What other term would you use for them?
Old Oct 9, 2005 | 02:25 PM
payneinthe's Avatar
A worthless waste of excess weight?
Old Oct 9, 2005 | 02:29 PM
2QYK4U's Avatar
Really? You dont find any benefit in the front/rear upper strut bars keeping the struts from flexing as much?
Old Oct 9, 2005 | 02:44 PM
payneinthe's Avatar
Umm... the S2000 doesn't HAVE struts.
Old Oct 9, 2005 | 02:52 PM
2QYK4U's Avatar
Ok...shocks. I am not trying to be a jerk or argue with you, but most of the cars that autocross in my local area have strut and tie bars.
Old Oct 9, 2005 | 03:31 PM
payneinthe's Avatar
The S2000 doesn't need them. Yeah, if you're driving an accord or civic, they probably make a little difference.
Old Oct 9, 2005 | 03:35 PM
2QYK4U's Avatar
Ok...thanks for the knowledge and saving me money.
Old Oct 9, 2005 | 07:01 PM
WarrenW's Avatar
Putting on a strut/shock bar will take you out of stock class and into SP (street prepared). In fact, all the parts you mentioned will do the same, as will bigger and/or slotted rotors, bigger calipers and more. Once you do something that puts you into SP, you better be ready to spend a hell of a lot more money to go all the way into SP if you want to be competitive in your class.
A better way would be to go w/ a stiffer front sway bar (Comptech, Grindon(sp?), Saner, Small Fortune Racing, etc.) along w/ R-compound or A-compound tires (i.e. Hoosier R3S04 or A3S05, Khumo V710, etc.) which you'll need to mount on a second set of stock wheels (or at least stock size). To stay in stock, you can use any wheel you want as long as it's the same diameter, same width and no more than plus or minus 1/4" difference in offset over stock.
Another upgrade that's legal for stock is shocks. Koni Yellows are a popular choice. They're one way adjustable (rebound only) and around $650 for a set. Penske and the like are even better and double adjustable to boot. But they're waaayyy more expensive ($1,000 PER CORNER!!!)
Something else you'll need to improve is the loose nut behind the wheel. This maybe the least expensive and show the biggest improvement. I'm taking the DC Region's Level 3 school nest weekend. You can also attend an Evolution school. Your SCCA Region will also have schools in your area from time to time.
That's all I got, back to you...
Warren
