autox question, mechcanic problem.
Old Aug 28, 2006 | 11:27 AM
J's AP1's Avatar
Default autox question, mechcanic problem.
course map http://fastaudi.net/racing/Cacc_regi...ide_course.pdf
after G circle, exit at the straight(1st gear around 6rpm) my rpm just drop to about 2k. so it drop 4k
i don kno what happen, but it had happen 3 time in the same day, same spot. also i had happen couple time before. also everytime it happen it is happen after g circle turn and going big straight. oh also...if i shift to 2nd gear in the straight at 4k rpm it doesnt happen.
plz help.
i've ask other, they say is spark plug. i will change too. but what if not..than...??
sorry for the bad english.
Old Aug 28, 2006 | 11:31 AM
payneinthe's Avatar
How much fuel did you have?
Old Aug 28, 2006 | 11:38 AM
Conedodger's Avatar
Old Aug 28, 2006 | 11:57 AM
J's AP1's Avatar
abit less than half.
also i thought the fuel is by pressure??
Old Aug 28, 2006 | 12:02 PM
payneinthe's Avatar
Definitely fuel starvation. For autocross, you need at least 2 bars over half, or you'll experience exactly what you saw.
Old Aug 28, 2006 | 12:39 PM
drivefast617's Avatar
Probably not the same thing, but after purchasing a used s2k, I experienced alot of power loss only in tight turns (like the one you show).
It ended up being it was 2.5 quarts of oil low!! added 1 quart at the track and it woke up. added another 1.5 quarts and it really woke up.
Supposively, in a turn, the oil will slush over to one side making the car think it it really low on oil. But when you straighten out, it goes away.
Just something to check.
Old Aug 28, 2006 | 02:53 PM
J's AP1's Avatar
i mean it happen AFTER the turn and exit to the Straight(thats when it happen).
sorry for the misunderstanding. oh and i always check the oil b4 & after autox. i don kno if its good or bad, but my car dont burn oil. i mean very very little.
my bro itr burn ALOT of oil, even stock.
Old Aug 28, 2006 | 05:06 PM
CRDMS1's Avatar
How long did you run it on the track like this? And you ran it some more after only adding a quart? Have you checked compression & leakdown since?
Old Aug 29, 2006 | 07:27 AM
Sorry to hijack the thread but i'm glad you had enough OIL. In response to CRDMS1's question... (keep in mind I couldn't tell that I was low at all till after the event because it was TOO under the oil stick).
I had a codriver, so I ran it for 6- 35 second runs with 2.5 quarts low. It accelerated about like a miata with a good launch and vtech was pretty weak. vtech was VERY weak in transitions.
then, I checked oil and was unsure if it was low or high because of where oil line was (which was sloshed all around). Several other autox's thought it was full, but i really wasn't positive. For safety at lunch, I went to get a quart of oil (to be on the safe side). So, then I added 1 quart to see, and it had a small drop at end of dipstick, but I still thought maybe the line was above high. A few people thought it was overfilled now and I couldn't really get a good reading.
(So now, it was 1.5 quarts low but again, I didn't know this).. Then, I ran 2 runs. then it rained on us and the event was canceled. Here the car accelerated MUCH better going straight, and still not so good in transitions. But I acqured the car a day before, understanding the vtech in transitions was difficult because I couldn't compare it to anything.
Then, I drove home and thought about it. The car OBVIOUSLY was low on oil on first runs, but after adding the oil, the dipstick readings didn't change really at all. "Maybe it was WAY too low before and still kinda low now". I had to change the oil anyway because I just got the car a day before, so I went to get the oil changed and they said it was 1.5 quarts low!!!!
As you asked also, "Have you checked compression & leakdown since?" .. No I haven't (and don't know what it is) but I'll have it done to be safe.
Thanks and glad J's AP1 had OIL
Old Sep 8, 2006 | 04:14 PM
J's AP1's Avatar
well, i just have it check couple days ago. ALL of my spark plug need to be replace(the mechcanic say leak oil or something like that). well right now it felt much better and the engine sound louder too(but just has test on street/parking lot). i thought spark plug last atleast 40,000mile even autoxing??
Gernby
Sep 30, 2010 10:24 AM
brimstone
Jan 23, 2007 06:20 AM
s2cmpugh
Feb 12, 2006 04:07 PM
[ llcrayonll |>
Dec 30, 2003 11:54 PM
DoubleB
Sep 10, 2001 06:48 AM
