Bilstein PSS9 Damper Setting
Old Dec 4, 2007 | 01:08 AM
3r1k's Avatar
Default Bilstein PSS9 Damper Setting
What damper setting do you guys use when tracking with PSS9?
Do you guys use linear setting i.e setting 5 for front and rear or different setting for front and rear?
Cheerz
Erik
Old Jan 2, 2008 | 05:18 AM
manuelisfun's Avatar
How do you like your PSS9s?
Old Jan 2, 2008 | 06:53 AM
Turn-R-Us's Avatar
don't use pss9 for the track.
Old Jan 2, 2008 | 12:56 PM
coldrsx's Avatar
^y?
Old Jan 2, 2008 | 01:21 PM
Project22a's Avatar
Nothing wrong with using PSS9's on the track if you're on street tires. They ARE on the soft side as far as spring rates go, so they won't play well with R-Compounds; but other than that I don't see any reason why they shouldn't be used on the track.
As for the settings, set the rear softer than the front if you're having problems with your rear sliding out. It's all trial and error really.
Old Jan 2, 2008 | 03:39 PM
negcamber's Avatar
Shoot a PM to Fyrestrike...he runs PSS9s and is a Chin Motorsports instructor for track days.
Old Feb 8, 2008 | 04:10 AM
3r1k's Avatar
My car is fine with R comps on the track and it's pretty good but I couldn't get the heat to the rear tyres, on the bright side it's better than using street tyres
Racecar100
Jan 16, 2016 11:14 AM
IIGQ4U
Mar 26, 2014 04:29 AM
WynnS123
Nov 16, 2013 05:09 AM
nzouk77
Jun 30, 2008 12:36 PM
little wing
Apr 13, 2007 03:17 PM
