Brake Ducts
Old Sep 6, 2010 | 05:20 AM
turbo8765's Avatar
Default Brake Ducts
Anyone try these or have any experience with this vendor?
http://store.quantummotorsports.com/index....4qj0avhufeqjto4
Old Sep 6, 2010 | 10:28 AM
dan_uk's Avatar
I have that kit with the Ap1 ducts its pretty good
it has usual problems of ducts contacting the wheels a-arms etc and tearing I just duct tape them
Old Sep 6, 2010 | 11:12 AM
turbo8765's Avatar
Any pics on your car?
Does the CR come with brake ducts?
Old Sep 6, 2010 | 11:22 AM
PedalFaster's Avatar
No, it does not.
Old Sep 6, 2010 | 11:32 AM
racecar fun's Avatar
here's a site w/ great pics and instructions for making your own/installing brake ducts
http://robrobinette.com/S2000BrakeDucts.htm
Old Sep 6, 2010 | 04:42 PM
NewScooby's Avatar
I've had the kit on my car for a bit over a year now and I am fairly happy with it.
If I could do it over I would/or have done the following....
- The ducting can definately take the heat, but it is falling apart due to contact with the wheel and rubbing at the fender liner passthru. When I replace the ducting this fall I will be putting a grommet around the finderliner passthru to prevent chaffing(vacumn hose with a slit longways siliconed on the fenderliner should work)
- I riveted on the spindle ducts instead of using the tiny nuts and bolts the kit came with. Just one less thing to worry about imo.
- use tape on wheel weight with metal tape over them reflect heat and provide a smoother surface for the duct to make contact with. Hammer on wheel weights will chew up the ducts good.
- I would purchase the inlets and spindle brackets again and get the 2" brake ducting elsewhere.
Old Sep 6, 2010 | 04:59 PM
turbo8765's Avatar
Why get the ducting elsewhere? Simply cost?
Old Sep 7, 2010 | 07:36 AM
NewScooby's Avatar
Just not impressed with the quality of the ducting that came with the kit. My cousin has ducting from HRPWORLD that is solid vs the stitched together style that came with the kit. To me that looks to be better quality, so i will be going with it when I go thru the car in the off season.
Old Sep 7, 2010 | 09:25 AM
patinum's Avatar
I have this kit and I'm pretty happy with it. BTW, probably obvious, but it doesn't work with non-staggered 255's on 17x9 +63.
Old Sep 8, 2010 | 06:05 PM
markhs2's Avatar
What wheel sizes with offsets front and rear and tire sizes are you running with this kit?
Thanks
