Brake Help: 355mm (~14") front rotors?
So I am trying something a little different. Is there anyone here running a 14" or 355mm front rotor? I am concerned about clearances to the ball joint and would appreciate any help. Also, I am trying to establish if there is a major issue with the master cylinder not being able to provide enough pressure for significantly larger calipers. I know pedal travel will be compromised, by how much is my concern. If I have to lose the ABS and go to a twin master cylindered Tilton unit, I am will evaluate if that is worth the hassle over selecting an off the shelf system.
Regards,
Asura
Regards,
Asura
Originally Posted by S2FARSI,Mar 2 2008, 08:17 PM
There is somebody on this site running a HP racing 8 piston bbk with a rotor that size. I cant remember who the member was. You might want to contact HP racing and see if they give you some info.
I can get some pics of the set-up if you would like to see specific clearances.
