Budget B street setup for 2014
Alright, you guys are convincing me I need the bar. I may go with the moddiction if it comes out anytime soon, and upgrade to a gendron later if I need to. Sticking with the stock shocks for now, since I only have 28k miles, but that will be upgraded to revalved Konis at some point in the distant future probably.
That being said, if you were buying the bar and tires at the same time, what sizes would you go with. I know many are saying 245/255, which is what used to be common for stock class with R comps, but does the 245 really work ok with a street tire and a 7 inch wheel being pinched that much? Street tires don't take nearly as kindly to pinching. That being said, I am in an AP2v3 so it understeers a lot more then the AP1s, so maybe I need as much tire as I can get?
My experience is coming from a heavily camber challenged BMW 135i that I pinched 235s on a 7.5 inch wheel and then overinflated to get some camber on the actual tire profile, so I am not used to the type of setup required by an S2k, hence why I am asking here. My gut (which is probably wrong) is you don't gain anything from going even more pinched since you don't need the camber and you'll end up with a rounded tire profile that won't have the flat contact patch that a smaller tire would. I could be completely wrong though, that's why I ask!
I have been of the same opinion as you on the front tire size for street. I have always run 225/255 but have ax'd another B street similarly prepared with a 245/255 combo. Honestly didn't think the 245 had any advantage. Although, all your national level drivers are running the 245/255 combo. I guess besides a few extra $ and slightly more weight there is really no penalty for the 245s and there is possibly a slight advantage.....so go with the 245/255 combo.
I am assuming all along you are running max camber and caster settings. I am right at -2 camber and 6 caster with zero toe in the front and -2.4 camber in the rear with just a bit of of toe in.
I've got a 125$ used whiteline front bar and some used 300$ zii's (almost new 205/50/16's) and have paxed 5th on my first 2 different local Scca event. The car came with a cat back when I bought it. I will probably buy the moddiction bar if it ever comes out because the car was a little tail happy on concrete but the balance was good on blacktop.
it will rub the liner a tad under hard cornering. get the bar if you plan to be competitive at your local event. it makes the car so much more manageable. not saying that you couldnt without it.
you should drive it without first then put it on and see if it made a big difference.
The 225/45s slightly touch the inner fender on the most extreme ax sweepers but with a lower profile and smaller diameter of the 235/40s, I am hoping to get away with them
