Camber Question
Get the S2. I can run up to -3.3 or so in the front with S2, but I back it down to about -3.15 so I can run a decent amount of caster (6.4 degrees). I don't think the S1 will do much, unless you plan to lower your car also.
You need at least -3.0 in the front and rear. More negative camber in the front works better.
I'm kidding...before I adjusted my camber after the install, I was running -3.2 up front. I backed it down to -2.5 for now. I will bring it up to -2.8 for the next trackday. I'm maxed out in the rear at close to -2.8...so it's not too crazy.
Bringing this back - So has anyone gotten an idea of how low you can get your camber, either stock, with the S1 joint, or with the S2? I have this same question - S1 or S2. I have a non-CR 2006 and I'm guessing I'll want around 3 degrees of camber up front. But potentially I'd want to be able to go down to maybe 2 degrees of camber.
Can an S1 get up to maybe 3.5 degrees of camber in front?
Oops, forgot to mention ride height. Yeah I'm thinking 12.75"-13" wheel center to fender height.
Sounds like I should probably do the S2, especially if I want to play with caster at all. At the same time it sounds like the S1 wouldn't be the end of the world if I can't find an S2.
Thanks for the help guys.
Interesting curves, thanks! These were measured by moving the suspension through its arcs? What was the caster setting? I guess the stock adjusters weren't maxed out?
Also, it seems the S2 only added a bit over 2 degrees? Or were the adjusters changed to different settings?
Per Evasive, my car maxed out at -1.83 on each side, while retaining the stock caster. The CR does sit higher than a non-CR.
I haven't tried to see how high I can get now, but the S2 is published to increase camber by -3; the S1 increases camber by -2.
