Canards
I'm running J's half spoiler with dual cannards.
I have some AP1 OEM bumper cannards that i bought from a member on here but never mount them. They are for sale if you are interested.
These are made by Zeffect.
I'll see if i can find a pic of how they are mounted.
how about these from pwjdm?
Street (small):
http://passwordjdm.com/PasswordJDM-D...P2655C428.aspx
Race (large):
http://passwordjdm.com/PasswordJDM-D...P2656C426.aspx
Street (small):
Race (large):
The Zeffect ones look much better then the PWJDM, plus they would probably channel some air to the brake ducts. You won't get meaningful downforce from either, and without wind tunnel testing to see how they affect airflow to your wing, they'll probably do more harm (drag) than good (energized flow to the endplate region).
"Set at 22.5 degrees of rake, the Password:JDM Dry Carbon Street Canards will generate 43lbs of downforce per side in the frontal corners starting at 40mph. That is 86lbs of downforce up front without the use of any additional splitters... with the use of a functional front splitter, you can balance the amount of downforce required as per your setup and application per race track." this is for the street one from pwjdm. sounds like "meaningful" downforce to me
